Would this flashlight mod work? Vector SLH100P HID to XHP70.2 conversion.
I have a Power on Board Vector SLH100P High Intensity Discharge Spotlight 6000K 35W with a 12V 9Ah Battery. I don't really use it but keep it charged up just in case... It has 1 mode (bright) and its a battery hog. I have been thinking of pulling the HID out and putting in something like XHP70.2 or 70.3 de-capped on a heat sink in its place and using "Buck Boost Converter":https://www.amazon.com/dp/B0978T3JKH/?coliid=I372X7P574CY5Y like this one, setting it to 12V in/out and adjusting the amps going to the led with it, thus making it a dimmable light.
Would that work or do I need to use PWM to dim it?
What kind of run time would I get at full 12V 2.4A? Double run it at 1.2A?
Would I need a new reflector?
Would the XHP70.2 be brighter or dimmer than my current 35W HID bulb?
Edit: Just got the Buck-Boost ZK-4KX converter. I will work but not as nicely as I hoped. I was hoping to be able to set voltage to 12V, the amp limit to 2.4 and just spin the knob to control from 0-2.4 no such luck. I can set a cut off limit but the knob will still go to 4A, it will auto power off once I go over the set 2.4 so I have to always watch the current as I crank it up, also to change the current I need to push U/I button 2 times to get to current, and now I can control the thousandths amp place, pressing the knob changes to the hundredth place, pressing it again to the tenths place... So to change brightness I would need to press 3 or 4 buttons and then twist the knob. I guess I will live with that. Just found out that if you use the on/off on the converter it will allow full amp draw for 1/2 second before it starts to limit the current down to your set point. Attaching load after converter is powered up keeps the current at set point.
I did a mod like this and it’s not easy or straightforward.
LED Conversion
The HID reflector won’t work with the LED, so you need to swap or modify the reflector.
It is a good learning experience though!
Thanks for the reply, I took a look at your conversion and it’s in line with what I was planing. I will do some heat tests first but my plan is to add 2 thermal switches, normally open at maybe 50-60C that will turn on the fan, and a normally closed around 90-100C to kill power to the LED if it overheats. Everything is ordered except the reflector, lets see how everything turns out before I decide if and what reflector I will try. Would love to make it a zoomable but that may be to hard to do and keep it looking normal.
Next time I have to replace this 12V9Ah lead acid battery I will get a same size 12v lithium.
Cool. It would be neat to see your progress. Maybe you can do a build thread for this?
