I have purchased two c12 and both have had to be fixed. One was missing O rings and the other one had really bad threads and is almost worthless.
Has anyone found a seller that will send a "good" one ?
Thanks!
Thanks!
I bought this one from alixpress and came very well lubed and came in mint condition.
XP-L C12
downlinx please what is the type of the driver you found in your C12 and what is the tail cap reading on high ?
I am pulling this info from lag man as my fluke is out for repair.
But it looks like a direct drive.
Stock, the driver is pulling about 1.0A with a battery at 3.5V
Stock, the driver is pulling about 1.9A with a battery at 4.0V
Adding brides cable will get jump a slight jump.
Cell at 3.45V: 1.3A
Cell at 4.15V: 2.9
Thank you for your trouble!
I have XP-L C12 from the same seller and mine came not in so good condition. Threads are quite rough and it was flickering badly, I had to remove some solder from driver retaining ring to fix it.
