WTB DST ( Defiant Super Thrower ) Pill.
I’m looking for a DST pill. It doesn’t need to have a driver or star/LED.
I’m wanting to keep my stock pill with dedomed stock emitter, short spring for 1x18650 as a backup pill, and mod the new pill with xml2 dedomed, 5amp driver, long spring for side switch and 2x 18650.
I say, "Screw the Pill". Actually, more accurately, don't screw it. The DST has a big flat area (approaching 2 inches in diameter) on the top of the head. Cut a few disks out of copper sheet, reflow them together, mount them to the top of of the head. Then just add whatever sized copper pipe to the bottom to fit the driver of your choice. Biggest you can fit without boring the head is 1" (ID) diameter copper pipe.
I started one like this for an MT-G2 build. I'll snap a couple pictures tonight.
Ah! I see what you’re talking about. I’m terribly uncreative; I’ve seen what you described 5+ times in the forums, but never thought to apply it to this.
Would there be any way to fill the void (for thermal transfer to the fins) between the copper pipe and the threads the stock pill screws into, without making it difficult to remove the new copper insert from the head?
I imagine you would get decent transfer if the copper pipe fits slightly snug. The stock pill only has threads over a small portion of the pill's height. And threads usually only make contact on a portion of the side of the tooth that has pressure against it. The copper pipe would have contact along it's whole length.
In my case, I didn't want to purchase 1" pipe. So I made my "pipe" using a 3.5" strip of copper sheet. I shaped it by bending it around a 1" wooden broom handle. I made it so that it would have to be pressed in. So it's not coming out unless I cut it out. In your case, you would make it just snug. You could then use thermal paste if you wanted.
I have a spare standard pill but not sure what postage would cost to wherever you live?
If you end up not finding a pill or decide to go copper instead, I posted some info and pictures here.
