WTB: some 16340's
looking to buy some good rechargeable 16340’s for a surefire host and sportec triple nichia drop in p60 if anyone has some new ones. tailcap can handle 5A if that helps.
will be using a VP1 charger.
im in london.
thanks.
You might want to check out this site. They have e-fest IMR 16340’s I think they are in the UK. You should be able to find a 20% off coupon on the site as well. bringing a pair down to $8. Really good batteries. I don’t know what your shipping would cost. But it’s worth a shot to look.
http://www.liberty-flights.com/product.asp?id=106
That appears to go to an Aussie site. One I knew nothing of, cheers 18sixfifty.
Edit: URL is changed, it must redirect based on location… and sadly shows nothing of interest to me… bugger thought I might find as local source of batteries with reasonable prices.
how the heck did that get there?
I don’t know why the site is this way, but you have to put in the number you want and then hit update basket.
Nah, the Aussie version is awful, I cant even see where Id add a part number even if I had a part number to use. I tried adding the product number you listed, 404.
What I can find is $35 for a black 650mAh battery, specific to ecigs, or $35 for a steel coloured one. No more batteries on offer.
URLS look like http://shop.liberty-flights.com.au/products/liberty-flights-ecigarette-battery-steel
Aussie site is vaping specific it would appear. Never mind me. Move along, nothing to see here.
Oh well, bummer about that.
Flashaholics UK
LEDFire Torches UK
Torchy Ebay Store
UK Bright Ideas Ebay Shop
Ecoluxshop Ebay
thanks !. just got an order on hold from flashaholics.
i have ordered some AW 550mAh IMR 16340’s ; Fenix, Nitecore, Zebralight, Eagletac, Olight and Maxpedition
are these alright?.
i did also notice some RCR 16430’s at 750mAh.
what to go for?. one is IMR 500mAh, the other is RCR at 750mAh .
thanks.
They are both good cells, i use them.
They have about the same capacity under lower current draw but the IMR cell will supply full power at higher loads.
This information comes from HKJ’s Reviews
The IMR cell doesn’t have a protection circuit that makes it “switch off” automatically when it gets too depleted so you need to be careful not to drain it too far or it will be damaged, although it is a more robust chemistry than the ICR.
These batteries are great for high power lights with built-in low voltage protection or indication.
hey CRX,…
BIG thanks,
i went ahead and ordered. IMR.
will probably charge the battery when it’s half way down.
thanks.
You can choose among these 16340 | akkuteile.de :slight_smile:
