Like I said, I want to buy a single or multiple of the lowes aaa lights that lumatic showed us a while back. They a no longer available and were sold on clearance for a while.
Name your price.
Thanks!
Name your price.
Thanks!
I have one that I made direct drive with an xre R2 reflowed to a copper sink and uses the stock lens focused to a square die. I have an unmodded one also. Will sell the stock one for cost($3) plus shipping or the mod for $10 plus shipping.
If Trak doesn’t want it I’ll take the modded version.
The lens on the mod is supported above the Led by a section of copper pipe. Reversing the lens and using a shorter piece of copper(incuded) blurs the image to a more floody spot. I’ll give TT until tomorrow to respond, then it’s yours NAWJ. FYI, I have no idea how long the switch will last with the mod pulling ~2A through it. It was done as a nod to Lumatic back in January and I mostly use it to carry a spare 10440 for my solitaire. Here are 3 AAA mods: Solitaire, AAA Minimag, Utilitech.
With their respective hsp’s,
Either TrackTuned didn’t check this thread or he’s found Lumatic’s stash so if you still want the modded Utilitech Notawhackjob, pm me and we can do a deal. Shipping from NoCal to SoCal shouldn’t be too bad and you should get it quickly. I’ll be posting beam shots late tonight in another thread and I’ll put one here as well.
Havent checked my thread ![]()
I want the stocker if you got it. I do request beamshots of the mod though!!
That sucker pulls 2A direct drive? I am fitting a driver in mine with a square die projection as well. I already made the copper pill and ruined my driver……broke the trace on the stock driver. It does come with a boost driver that puts out 2.6 volts no load that I will try first. I am ordering a single aaa driver for an eneloop that I will drop in it instead!
This is the thread for it. Fresh of the charger with fat leads I read 2.5A from the DMM. Obviously a 10440 can’t sustain that but it’s still pretty impressive. It’s my only thrower so I don’t have anything to compare it to throw wise. As I stated in the build thread, I seriously doubt the switch can handle the current but I did replace the contact with brass and lowered the switch resistance. Anyway, here are a couple of beamshots. Taken after the build,
And taken last night,
With thin leads and Vb at 3.8V I measured only 1.2.
If both of you will pm me your addresses I will send the lights this weekend and let you know shipping costs. I usually just go USPS 1st class. Btw, both protected and unprotected cells fit in this light.
Bort has one with more sedate mod, the stock components removed from the board and replaced with 2 7135 chips and the lens replaced with an 18mm op reflector and glass lens. This is the build thread for that version.
