contactcr
(contactcr)
261
Probably not. You are testing the worst combo though. Low power, smo reflector and AR lens.
I bet if you remove lens and use a 14500 it will be less bad ( but still not FA3 )
All just a guess though since there’s only limited data for FA3
contactcr
(contactcr)
262
You may want to consider getting like a $5-15 adjustable buck power supply and cutting up an old DC power supply. This way you can test with a known current and easily drop other optics on top.
I use this: ICStation DC-DC Adjustable Buck Converter 5.3V-32V to 1.2V-32V 12A Voltage Regulator Step Down Module LCD Digital Voltmeter Ammeter with Shell https://www.amazon.com/dp/B07KYJ4L48/
azhu
(azhu)
263
I actually recently got a DC Power supply. Haven’t tested it out yet.
I also just remembered the lights were all tested with dc fix on. I bet that had something to do with it.
The SST-20 I tested was from a J4 flux bin. I also have J5 flux bin that I will test tomorrow probably.
azhu
(azhu)
264
UPDATE:
3000k sw30 d180 L2 r9080 Out of stock. Restock beginning of Oct.
3500k sw35 d200 L2 r9080 Out of stock. Restock beginning of Oct.
4000k sw40 d220 L2 r9080
4500k sw45k d200 L2 r9080 Out of stock. No ETA on restock at the moment.
Joshk
(Joshk)
265
I tested these emitters on my spectrometer at 4 different power levels. Check it out here
1stein
(1stein)
267
Just received mine, flawless condition. Many thanks azhu!
azhu
(azhu)
268
UPDATE: I have sw30 and sw35 in stock again.
1stein
(1stein)
269
Great. May i have 4x sw35 please?
1stein
(1stein)
271
Thanks. Waiting for delivery
Ah, forgot to report in.
LEDs were received in New Zealand safe and sound.
Thanks for the service!
azhu
(azhu)
273
Good to hear! Don’t forget to post pics of your mod once you use these emitters
shirnask
(shirnask)
274
I would like 30 of the sw35’s please
azhu
(azhu)
276
UPDATE: I have a lead on some more sw45k but I’d probably need a minimum of 200 pcs to make the purchase worthwhile. Anyone interested in another group buy? If so, please let me know how many you’d like.
azhu
(azhu)
278
Added you to the list. Thanks!
sw45k (4500k, below BBL) group buy:
50 pcs aZhu
20 pcs pol77
10 pcs candor
gcxmr2
(gcxmr2)
279
I’m in for 50 pcs of the sw45k.
cetary
(cetary)
280
I’ll take 12 of the SW35. Also, is the SW27 still a no-go?
