As gorgeous as this light is (at least to me) I have decided to part with it, as I don’t really have much use for the tactical UI, and I’m not really into shelf queens (yet)
All of the relevant information can be found here:
https://www.olightstore.com/warrior-x.html
(only difference between this light and the listing on the Olight website is that this is a limited edition in the Desert Tan color)
Light has very minimal use, never outdoors, and probably less than 20 minutes of total runtime.
Due to a bit of carelessness on my part (although you’d have to be extremely careful to avoid this) there are some small “nicks” in the anodization of the metal tactical grip ring from when I swapped it with the included rubber grip ring and it rubbed up against the threads for the tailcap. This is only visible when looking down the body of the light lengthwise.
There are also wear marks on the anodization where the clip attaches to the light, but these are impossible to avoid when removing the clip, and are completely covered up by the clip or grip ring depending on how you have the light set up.
Light will be shipped in it original box, and includes all the accessories it came with:
-holster
-manual
-magnetic charging cable
-rubber grip ring
–18650 Olight 3000 mah high discharge battery
Asking $75 plus shipping CONUS only
