WTS - two custom flashlights ( triple and quad-led)
Hi.
I want to sell two custom flashlights - triple and quad-led.
Price for any flashlight - 89 USD via PayPal ( PayPal.Me ), free shipping with photos of parcel and tracking.
You can pay as “for goods”, because I’m a new member on this forum. Before I have sell my lights at eBay ( member id: b_mikhail88 ) and forum.fonarevka.ru Photos from my eBay lots.
First light - triple:
Inside:
- Optics Carlco 10507;
- LEDs in combination 2xXPG R2 (5000K) 75 CRI - 2 neutral and 1 warm XP-G, 90+ CRI, Q2 Bin, 7B (3000K). The light-mix temperature is a neutral;
  • Pulsed buck driver at 2.3 Amperes (4 mode - 40, 170, 680, 2300 mA);
For more information on the driver:
Driver - swith-mode constant current buck driver for CREE LEDs;
- Extremely high efficiency (95-99%);
- Smooth start;
- Battery level indicator. Inicialized by doubleclick, blinks 1 to 5 times depending on supply level (0.35s between clicks);
- 4 constant current modes. No strobe and SOS;
- Overdischarge protection (auto turn off at 2.75V);
- Auto switching to lower modes at critical discharge;
- User calibrated thermal protection;
  • Last mode memory;
Package including (in this lot you buy):
Custom mode flashlight on 1x18650;
Second light - quadled:
Custom made quad-led flashlight on 1x18650 with 3 modes:
  • Hi : 100% 3040mA
  • Med: 35% 1064mA
  • Lo: 2% 5mA
Inside:
- LEDs in combination 2x cold XP-G2 + 1 neutral XP-G2 and 1 warm XP-G2. The light-mix temperature is a neutral;
- New KDLIGHT V3 17mm 8 x AMC7135 1-Cell 3.04A 16 Groups Driver Board (Long Spring ver.);
  • Custom aluminium drop-in;
- current regulation for all output mode (no PWM flicks even at Low mode)
- battery reverse protection\
- as low as 3mA-5mA for low output mode
- 8 x AMC7135 380ma IC, Constant regulated at 3040mA for High mode
- 1oZ copper PCB, immersion gold surface
- 17mm diamter, 1.6mm double sided PCB and less than 12mm overall height that allow to be used on most of pill
- Spring material: Brass material with silver coated with good electrical conductivity
- Spring Dimension: 12mm (H), Spring Wire Size: 0.7mm
- total 16 programmable outputs (Please ref to the user manual for detail output and connections)
- Input Voltage Support: 2.6V - 4.5V
- Battery types Support: 1 x Li-ion or 3 x NiMH / alkaline
- Mode Specifications:
Hi : 100% 3040mA
Med: 35% 1064mA
Lo: 2% 5mA
  • Low voltage warning:
    When the voltage is below 2.8V, it changes to Low mode (1 ma) and flashing every 60 secs.
    And the cut-off voltage is at 2.6V, LED will be turned off.
Custom mode quad flashlight on 1x18650;
Welcome to BLF!
Good luck with the sale.
Thank you. :slight_smile:
