Tesla has chosen the 21700 as its battery and it’s now matching 26650 specs at a fraction of the size (21x70mm vs 26x65mm). Some people think that the 21700 battery will eventually replace the 18650 as the standard lithium battery. The 26650 battery size is probably obsolete and won’t be developed any further. They’re noticeably heavier, but fit in the hand and balance well.
The flashlights look rather similar. One could be newer and more refined. One of the important things is the UI and whether its straightforward. You want to look up the UI for that company and see if you will like it. Having good usable modes, like 5,30, 50, 100% is important for a versatile flashlight. Some people like a firefly mode.
I’m sorry that I’m not comparing the two flashlights. I don’t think there is a Wuben club here so you won’t get a good in depth answer. There are probably other comparable lights for less money. The go to 26650 xhp70.2 flashlight go to flashlight here is the Thrunite TC20. Its compact and has the best run times, but its not usb-c.
