1. Multiple modes
Outdoor mode (with mode memory function): there are 4 brightness levels (High/Med/Low/Eco) and 2 flash modes (Strobe/SOS) for different uses.
Tactical mode: there are 2 brightness levels (Turbo/Low) and 2 flash modes (Strobe/SOS) for tactical use.
2. Rechargeable Batteries Included
The flashlight is powered by 2 pcs 3400mAh rechargeable 18650 batteries (included), it can last as long as 468 hours (Eco mode) after fully charged. It comes with a dual slot battery charger, no need for extra batteries.
There is battery power indicator beneath the side switch, which will let you know the battery power status when using, it and tell you when it should be recharged.
When it’s lower power, you could use the dual slot battery charger to recharge the batteries, very convenient and environment-friendly
3. Ultra-bright Lighting and Long beam
WUBEN H8 LED flashlight utilizes a CREE XHP35 HI LED, emits light as high as 1800 lumen, and max beam distance is up to 3280ft (1000 meters).
Learn more about WUBEN H8
