This is the Wuben PL01, a penlight featuring a rechargeable 10880 cell with 600mAh, compatibility with AAAs, type III hard anodizing, LH351D LED in 5000K and more!
• Price
Coupon (5%): ULMPBR
The PL01 is currently priced at $19.99 on Wuben official website.
This link is an affiliate link, you can use it to buy flashlights you like and support me. Thanks.
• My opinion
The PL01 is a nice flashlight overall, the LED surprised me with it’s CRI, but the tint is a little greenish, the black anodizing feels pretty good and the dual fuel feature is pretty convenient, it’s also IP68 water resistant and seems well sealed.
But it lacks on the driver part, it’s not regulated and not has PWM on all modes, even with AAAs.
| PROS | CONS |
| Type III hard anodizing (Black color) | PWM on all modes except High |
| High CRI LH351D LED | Unregulated driver |
| Dual fuel feature makes this flashlight very versatile on emergencies | *Moonlight is a little bright, but acceptable for me |
| IP68 rating |
• Box contents
- PL01
- Wuben 10880 Li-ion cell
- USB-C cable
- Lanyard
- 2x O-ring
- User manual
• Body and build quality
Packaging: It comes in a pretty nice package, as usual from Wuben, a well made and nice unboxing experience.
Anodizing Colors/Material Options: The PL01 is available only aluminum with 2 anodizing colors: Army green and type III black hard anodizing.
Main body/Grip/Size: The main body is mostly smooth, this makes the flashlight a little slippery, especially when wet. The size is good for a penlight in my opinion.
Material: The entire main body of the flashlight is made of 6061-T6 aluminum.
Threads: The threads are trapezoidal and not anodized.
Clip: A stainless steel dual way clip with a black PVD coating comes installed on the flashlight, it’s pretty good to hold the flashlight on your pockets, especially on shirts.
Tail stand and rolling: With the clip the flashlight doesn’t roll much, though without it, the flashlight has no way to stop itself from rolling. The flashlight can headstand, but tail stand isn’t possible, due to the button rubber boot being directly exposed on the tail cap.
Magnet: No magnet by default on this flashlight.
AUX lights: No AUX lights are present on this flashlight.
Buttons: A reverse clip mechanical switch is present on the tail cap of this flashlight, covered by a black silicone boot, this means that giving a half click while the flashlight is OFF will do nothing, but when it’s ON it will cycle between brightness levels.
Battery contact: Contact is made with the battery by a gold-plated button contact on the driver and a gold-plated spring on the tail cap. I usually prefer springs on both ends to reduce the impact on the battery when the flashlight is dropped, but this button contact seems large enough to not dent the battery easily
Bezel: A simple smooth EDC-like bezel is featured on this flashlight, the glass lens sit slightly recessed under it to prevent scratches on the lens.
Water Resistance: The PL01 is rated to IP68 rating, meaning it can be submerged under water for at least 1 meter for 30 minutes. Wuben states it can be cleaned with alcohol.
Size comparison:
From left to right:
Convoy T4 Brass (2x14500) - Wuben PL01 (2xAAA) - Convoy S2+ (18650)
• Weight and size
Weight:
- With battery (Wuben 10880): 48.8g
- Without battery: 30.6g
- Battery (Wuben 10880): 18.2g
Size: 135.8mm x 14.9mm x 14.9mm - (height x head diamter x tail diameter) (without clip)
• Battery, runtime, and charging
Battery: The PL01 comes with a USB-C rechargeable Wuben branded 10880 “ABK600R” - which is the size of 2x 10440 stacked -Li-ion cell with 600mAh of capacity, 2xAAA batteries (Alkalines, NiMH…) can also be used on this flashlight as it has the dual fuel feature, this makes this flashlight very versatile, as it has a lot of battery options.
Battery Indicator: It does not feature a any type of battery indicator.
Powerbank/Reverse charging: No powerbank feature on this flashlight.
Charging: The PL01 doesn’t have charging on body, instead it comes with a USB-C rechargeable battery and also accepts AAAs for when the main battery dies. Charging input is 5V 1A, so 5W of input power. It charges in around 1h30min to 2h.
• Modes, Runtimes, Throw, Candela
Modes: The PL01 has 4 brightness levels: Moonlight - Low - Medium - High. No blinkies, SOS, strobe or anything like that, just simple and straightforward brightness levels.
Specs (10880):
| Level | Advertised Brightness with 14500 (Lumens) | Measured Current (at tail cap - Wuben 10880 at 4.15V) | Advertised Throw (Meters) | Advertised Runtime |
| Moon | 1 | 18.3mAh | - | 125h |
| Low | 50 | 210mAh | - | 7h |
| Medium | 150 | 430mAh | - | 2h30min |
| High | 650 - 150 | 1.97A | 110m | 1min + 1h |
Specs (2xAAA):
| Level | Advertised Brightness with AA (Lumens) | Measured Current (at tail cap - Panasonic AAA at 1.35V) | Advertised Throw (Meters) | Runtime |
| Low | - | 19.6mAh | - | - |
| Medium | - | 83.2mAh | - | - |
| High | - | 1.03A | - | - |
Turbo: The highest mode on this flashlight is “High” with 650 Lumens for around a minute before stepping down, it’s decently bright and useful for most tasks, but nothing super bright due to it’s size.
Moonlight: Moonlight mode isn’t perfect, it looks brighter than 1 Lumen in my opinion, but nothing too bad, it’s not as dim as I would prefer, but still useful without being excessively bright.
Blinkies: No blinkies are featured on this flashlight.
Lockout: No lockout - mechanical or electronic - is featured on this flashlight, as the threads aren’t anodized and there isn’t a lock mode on the UI.
Throw: This flashlight isn’t much throwy, as the focus it to be a diffused light for close tasks, but it still has a hotspot that can throw decently.
Throw measurements (10880):
| Level | Lux (2 meters distance) | Candela (2 meters distance) | Throw (ANSI NEMA FL1) (Meters) | Throw (Conservative estimate - 50% of ANSI NEMA) |
| Moonlight | 5 | 20cd | 9m | 4m |
| Low | 48 | 192cd | 28m | 14m |
| Medium | 151 | 604cd | 49m | 24m |
| High | 546 | 2.184cd | 93m | 46m |
• Emitter, reflector and CRI
Emitter: A Samsung LH351D LED in 5000K is featured on the PL01, similar to the Nichia 519A it’s a floody emitter with a pretty good CRI. but it has lower CRI and “worse” tint than the Nichia, though I was impressed this one had very close CRI to the 519A, the greenish tint is still present.
Lens: An AR-coated glass lens is present in front of the reflector to protect it from scratches.
Reflector/TIR: It features a 12mm diameter 6mm depth smooth reflector.
Beam profile: The beam has a floody profile, with a big slightly defined hotspot and a decent amount of spill.
PWM: Sadly, PWM is featured on all modes of the PL01, the only exception is “High”, with no PWM at all, other modes have a near 99% modulation depth. PWM uses frequencies above 20kHz, so it isn’t noticeable for most people. Even with AAAs this flashlight features PWM.
CCT/DUV/CRI: The CCT is around 4400K on moonlight, below the LED advertised (5000K), but gets to it on higher levels. Duv is positive, slightly on the green side. CRI actuall suprised me, I got pretty good readings, around 93 CRI and R9 was even higher than expected for the LH351D LED, around 94 R9.
*The CIE 1931 locus image is not centered, but the coordinates are accurate, so consider only the coordinates and not the location on the image.
All measurements made using Opple LM4 with the desktop app in a dark environment.
• Driver and UI
Driver: The driver seems to be a unregulated driver for 10880 and AA cells due to the presence of strong PWM. The efficiency of the driver is not as good as a constant current regulated driver, and the brightness will decrease with the battery voltage.
UI: The UI is pretty simple, full click on the tail switch turns it ON/OFF, a half click when the light is ON cycles through brightness levels. It has mode memory, no way to turn it OFF.
Low Voltage Protection/Warning: The flashlight will turn OFF automatically when the battery voltage is too low.
Reverse Polarity Protection: Electronic reverse polarity protection is featured on the PL01, so inserting the battery with the wrong polarity for a small time won’t damage the flashlight.
Temperature Control: The PL01 Temperature control, so when the driver gets too hot the flashlight will begin to step down. The step down occurs fast due to the small size of the flashlight and little aluminum mass to distribute the heat.
Thank you for reading my review <3
A special thanks to Wuben and Telma for sending this flashlight for me to review!
*I am not being paid to do this review, everything here is my honest opinion.
**Some links may be affiliate links, this doesn’t impact on my opinion for the reviews. You can support me by using the links to buy flashlights you like.
