Wuben Pre-release L1 - Units in hand - Ready to ship from USA
Hey all,
I have already received a shipment of Wuben L1 units.
They are in hand and ready to ship.
I only have the Nichia version…cause Nichia.
I truly do not have many units left.
CODE: L1
at check out and get 5% OFF
Just for my BLF peeps
Should pretty much cover priority shipping.
You’ll have the light in hand in 2-3 days.
Im here to tell ya it is a really cool light.
Light up the ground and in front of you at the same time.
Reach out to me if you have any questions. :slight_smile:
High Lumens: Max 2, 000 lumens output, with a 304-meter throw distance for effective long-range visibility.
Magnetic Tailcap: Attach the L1 to any metal surface, freeing up your hands for any everyday tasks.
180° Rotating Head: Enjoy ultimate versatility with the 180° rotating head. Adjust the light beam in any direction you need, whether in tight spaces, outdoor adventures, or for targeted lighting. Direct light with precision and control using the rotating head.
Long Battery Life: The 4800mAh battery provides up to 90 hours of power in Low mode.
Fast 2.5-Hour Charging: Quickly charging with using a USB Type-C cable, offering several days of continued use.
Powerbank Function: As a portable power bank to charge smartphones, earbuds, and other devices on the go.
L1 NICHIA LED Version: The maximum output of auxiliary light is 600 lumens, with an higher CRI value of over 90, it restores objects in their original colors better and it is suitable for both everyday use and professional shooting scenarios.
