The Wuben X1 Pro is a revolutionary flashlight designed for EDC enthusiasts, night riders, and outdoor adventurers. Delivering 13,000 lumens of power with dual-beam versatility, a modular cooling system, and exceptional ergonomics, it’s designed to perform and impress.
X1 vs X1 Pro – Key Upgrades
Beam Options: X1 Pro adds spotlight functionality (dual-beam: spot + flood), while X1 only has floodlight.
Design & Ergonomics : A more flattened, contoured design for improved grip and comfort.
Battery: X1 Pro uses replaceable 21700 batteries, unlike the built-in battery of the X1.
Vehicle Clip: Enhanced for stronger stability during hands-free use.
Cooling System: Modular 3W contact-style fan, temperature-controlled and replaceable.
Pricing:
X1: $179.99
X1 Pro Super Early Bird: $99
X1 Pro Early Bird: $119
| Feature | Wuben X1 | Wuben X1 Pro |
| Battery | ||
| Cooling | ||
| Reverse Charging | ✗ | |
| Beam | Floodlight only | |
| Grip | Standard | |
| Vehicle Clip | Plastic |
LED Comparison – X1 vs X1 Pro
| Spotlight LED | — | 1 × Cree XHP50.3 HI |
| Floodlight LEDs | 3 × Cree XHP70.2 | 4 × Cree XHP50.3 HD |
| Maximum Output | 12,000 lumens | 13,000 lumens |
| Maximum Beam Intensity | 23,000 cd | 35,532 cd |
| Maximum Beam Distance | 303 meters | 377 meters |
| Color Temperature | 6500K | 6500K |
LED Technical Details
| LED Model | Package Size | Rated Voltage | Typical Power (W) | Typical Luminous Flux (lm) | Emitting Area (mm²) | Luminous Density (lm/mm²) | Shape |
| XHP50.3 | 5 × 5 | 3, 6, 12 V | 25 | 3060 | 9 | 202 | Round |
| XHP50.3 HD | 5 × 5 | 3, 6, 12 V | 25 | 3060 | 9 | 202 | Round |
| XHP50.3 HI | 5 × 5 | 3, 6, 12 V | 25 | 2900 | 9 | 322 | Flat |
| XHP70.2 | 7 × 7 | 6, 12 V | 40 | 5270 | 15.21 | 206 | Round |
Unpacking – What’s in the Box?
Wuben X1 Pro flashlight x1
User manual x1
USB-C Cable x1
21700-4800mAh Battery x2
Technical Parameters
Maximum Output : 13,000 lumens
Beam Distance: 377 meters
Peak Beam Intensity: 35,532 candela
Waterproof Rating: IP65
Impact Resistance: 1 meter
Dimensions: 59.6mm × 29.5mm × 138mm (2.35in × 1.16in × 5.43in)
Weight: 242g (without battery) / 383g (with battery)
Battery Type: Built-in 2 × 21700 4800mAh
Charging Interface: Type-C (PD fast charging)
Charging Power: 30W Max (Fully charged in approx. 2 hours)
Input Parameters:
5V ⎓ 3A
9V ⎓ 3A
12V ⎓ 2.5A
15V ⎓ 2A
20V ⎓ 1.5A
Discharging Power: 15W Max
Operating Temperature: Automatic fan activation when internal heat rises
Cooling Fan Power: 3W
Download Wuben X1 Pro Specifications and Line Chart
Brightness & Runtime
| Mode | Output (Lumens) | Runtime |
| Turbo | 13,000 lm | 1 min + 1 hr 7 min |
| High | 3,000 lm | 1.8 hrs |
| Medium | 1,000 lm | 5.5 hrs |
| Low | 400 lm | 14 hrs |
| Eco | 20 lm | 220 hrs |
User Interface & Functionality Operations
Power On/Off: Press the main button once to turn on or off.
Mode Selection Switch :
Left: Spotlight only
Middle: Spotlight + Floodlight
Right: Floodlight only
Brightness Adjustment:
Press and hold to cycle through: Eco → Low → Medium → High → Eco
Release to lock brightness.
Turbo Mode:
Double-click in any state to enter Turbo.
Double-click again to return to previous mode.
Eco Quick Start:
- Hold the button while OFF to enter Eco mode directly.
Strobe / SOS:
Triple-click to enter Strobe; triple-click again to switch between SOS and Strobe.
Single-click to exit.
Lock / Unlock:
Quadruple-click while OFF to lock (the light flashes three times).
Quadruple-click again to unlock (Eco mode activates).
Fan Control :
Auto: Activates when the temperature rises; stops when cooled.
Manual: Five clicks turn fan ON/OFF; shuts off automatically after 5 minutes.
Battery Indicator :
Blue steady: 100%–90%
Red steady: 90%–40%
Blue flash: 40%–15%
Red flash: <15% (low battery warning)
Design & Build
Material: Aluminium alloy
Cooling System: Modular, temperature-controlled 3W fan (replaceable)
Airflow Design: Dual air inlet/outlet for effective heat dissipation
Grip & Shape: Flat, ergonomic profile for comfort and control
Mounting System: Solid zinc-alloy clip and rail for secure, no-slip accessory mounting.
Battery Switch : With locking mechanism for safety
Port Cover: Sealed USB-C port for dust and splash resistance
Rope Hole / Tail Loop: Compatible with carabiner or lanyard
Kickstarter Launch Details
The Wuben X1 Pro will officially launch on Kickstarter on October 30, 2025, at 8:00 AM EDT. Several pledge tiers will be available to backers:
Super Early Bird (1 unit): Limited to 500 units at $99 each, 34% off.
Super Early Bird (2 units): Limited to 200 units at $198, also 34% off.
Early Bird (1 unit): No limit at $119, 20% off.
Early Bird (2 units): No limit at $224, 25% off.
Early Bird (3 units): No limit at $313, 30% off.
Early Bird (5 units): No limit at $495, 34% off.
Backers can secure the X1 Pro at the best possible price before it officially reaches the market.
Add-on Options
Customize your X1 Pro or grab extra essentials with these affordable add-ons:
| Item | Price (USD) |
| Metal Bicycle Clip | 19/pc |
| Detachable Cooling Fans | 5/pc |
| 4800mAh 21700 Battery | 29/pair |
| 1/4" Thread Extension Spacer | 2/pc |
Stretch Goals
Once funding hits $100,000, every backer will receive a free USB-C charging cable. Back early and join the community making this happen!
Click here to back the project on Kickstarter and be part of the community bringing this one-of-a-kind flashlight to life.
FAQs
Q1: What LED is being used in the X1 Pro ?
A: The X1 Pro features a dual-beam system:
Spotlight LED : 1 × Cree XHP50.3 HI
Brightness: 3,500 lumens
Color Temperature: 6500K
CRI: 70
Floodlight LEDs: 4 × Cree XHP50.3 HD
Brightness: 9,500 lumens
CRI: 70
Q2: What is the power of the X1 Pro’s built-in fan?
A: The fan operates at 3 watts, providing effective cooling for sustained performance.
Q3: What are the charging and discharging rates of the X1 Pro?
A:
Charging: 30W
Discharging: 15W
Q4: Why is the X1 Pro not paired with a smooth reflector?
A: Using a smooth reflector can create hot spots in the beam, resulting in poor visual experience.
Final Thoughts
Be Among the First — Back It on Kickstarter
The Wuben X1 Pro isn’t just another flashlight — it’s a 13,000- lumen engineering breakthrough that redefines what power and portability can be. With its dual-beam system, modular cooling fan, and sleek ergonomic body, the X1 Pro delivers performance and design that stands apart from the crowd.
Click here to back the project on Kickstarter and secure your early bird reward before it’s gone!
Don’t miss out — exclusive stretch goals, like free USB-C cables, are being unlocked as the campaign grows!
