Wuben X1 Pro Torch Review
The Wuben X1 Pro is a fan-cooled torch powered by two 21700 cells. It has a Floodlight and a Spotlight. The battery compartment has a quick release lock. The USB-C port can be used as a power bank.
Is it better than the Wuben X1?
Here is my full review:
First impressions are very good. It’s very solid, lots of power, and very intuitive controls. Waiting for nighttime to see how good it really is!
The output is well regulated.
Drop tested ok :rofl:
Active cooling and heat dissipation is good.
I broke the balance charging by connecting the small pad and negative terminal to a bench power supply the wrong way. There’s physical reverse polarity protection, and flat top cells are too short.
Mine arrived today, the white version. Nitecore NL2155HP and NL2160HP protected batteries fit and I expect that the XTAR 21700HP button top protected battery should also fit based on listed dimensions. The stock Wuben protected batteries are rated at 20A continuous discharge per a web search and that is the rating for the Nitecore cells while the XTAR claims 25A continuous discharge. Unusual these days to find a newly introduced flashlight that requires protected cells. The Nitecore cells are a loose fit in the battery compartment so it is somewhat oversize in diameter. I measure it as 22.56mm diameter.
