The Wurkkos FC11 has a indicator light on the e-switch for battery level indication. I didn’t see on the UI chart any way to keep the indicator light on so you can find it in the dark. Is there a way?
This function is not available for the time being.The indicator light is designed to turn off after 5 seconds.thank you.
Power Indicator
The LED indicator in the side switch shows the power status for 5 seconds after turning the FC11 on.
Green = remaining battery power is good (more than 30%).
Red = remaining battery power is poor (less than 30%).
Flashing Red = critical power, replace or recharge battery as soon as possible.
Low Voltage Protection: If the battery’s voltage is lower than 2.7V, FC11 turns off automatically to avoid battery damage by overdischarge.
