Folding design (judging by the appearance?). Adjusting the temperature and/or brightness of the light with a dimmer. Magnet. Hook for hanging. Power bank function, 10W charging. Buck driver.
Hi Wurkkos, thanks for GAW.
I see that it is magnetic but I would like that it has hook so it can hang on tree.
I hope that potentionmeter can work on both stepped and stepless mode.
And of course it will be the best if light is powered by remowable 21700 high capacity battery.
Foldable housing.
Magnet in the top.
USB-C charging.
Potmeter for intensity.
Usable as a powerbank.
It look collapsible for compact storing, has magnetic base or top, rotary switch for on/off and brightness (simpler the better).
It also look quite nice beam wise, so high CRI LED in there, I hope.
But it does look like quite an interesting lantern.
Thank you for the chance on the giveaway!
Simple UI and not too many functions. Camping is only for a night or two so it doesn’t need over complicating like a lantern (LT1), just needs to make light a few hours in the evening. Collapses down to a lightweight puck for space saving in bag. Internal non-removable battery (too small for power bank). Easy to adjust light levels via dial on base.
With luck, some warm/cool tint shift.
Just pop it open and switch it on, get that fire alight, kettle on, sausages cooking.
I think BLF similar with wurkkos and lantern ,many “Successful comments”
A collapsable rotary light would be pretty cool and easy to pack/use!
Weight less than 100 g
No Anduril
Wire bail
IPX4
I’m guessing powerbank. Looks interesting. Thanks for the giveaway!
It has remote control!
Thanks for the gaw!
Red option, collapsible
It emits electromagnetic radiation in the visible spectrum.
The dial goes to 11.
That is a bit far fetched, don’t you mean?
It can be used hanging or attached(magnetic base).
Colour shifting ?
High CRI ?
Adjustable brightness (rotary)
Pocket sized
Integrated battery?
Can it be used as music speaker?
Power bank, rotary brightness control, LED charge indicator?
1.Magnet on the top side, can be attached with a hook holder.
2.USB-C charging port
3.360° Light
4.Brightness level control, which also functions as an on-off switch.
5.Powerbank Function
6.Waterproof
I wanted to say multiple color temps (2700k and 5000k probably) but I won’t say it… I’ll play safe and say it will have a magnet
I’m afraid it has non removable battery. I would prefer removable 21700.
Inefficient driver, visible PWM, low cri and/or high CCT, next mode memory, not-waterproof, collapsible but only without the cell, built in mystery quality cell, usb c charging but only with type A cable, weak magnet…
Think I’ve covered most issues
color mixing, magnetic head, retractable accordeon function, rotation UI for stepless dimming and more importantly RGB lantern FTW !!!
