Wurkkos HD02 mini. An answer to the question “What if the HD02 fit in my pocket?”
Listen. I love my massive multifunction lights barely wedged into my pocket alongside all of the other 6 or so things on my person every day. But there is something to be said about a comfortable, stylish, multifunction, EDC light that fits in seamlessly into my EDC rotation. A four in one light and it is dual fuel?!? The HD02 Mini is just that. Form, function, and style in a small package.
What’s in the box?
The HD02 Mini
14500 battery cell (already in the light)
USB-C charging cord
Spare O-rings
User manual
Build quality
Like so many of the Wurkkos products I’ve encountered, the HD02 mini just feels like it hits the sweet spot of affordable quality. The rotary mode selector dial clicks into place solidly and unambiguously. The switch itself is easy to compress and intuitively right where your thumb should be. The threaded tail is held in place tightly and the magnet within it is strong. The head bezel is held in place with 4 screws. The pocket clip is strong, though for some reason, not the right orientation for a reversible clip??? That’s a design choice so I’ll talk about that below. The part that has the HD02 standing out among the other EDC lights is the hinged side light of course. The side light swings out and holds its place very firmly. I haven’t seen any weakness in the opaque cover of the LEDs being a failure point. So maybe that issue has been resolved. One quirk I’ve run into is that the side light will turn on, even when closed and the manual lock engaged, if a magnet is placed near it on the right spot. This might cause a problem with accidentally draining the battery when stored next to some other lights.
Design
I really like the design choices Wurkkos made here. The overall size and shape are a great blend of compact enough to genuinely EDC yet packed with features. What really works for me is the cutouts in the aluminum body and the black accent parts against the orange body. It carries comfortably in the pocket, and the UI design is self-explanatory. The side light is an extra aspect that really does make it stand out. Especially since it has a charge level indicator on it. It shows a physical line that grows smaller as battery life is used and even changes color from green to orange to red. Also as mentioned above, it has a 14500 cell so it can take an off-the-shelf AA battery. This adds a lot of versatility. The two things leaving me scratching my head is the pocket clip and manual lock. While completely functional, it is a reverse clip. It has that bent back part that allows you to attach it to a hat brim. Except if you were to do that, the emitters would be pointing at your face… this seems like a slight oversight. And I like the hidden charging port and a manual lock sliding switch. I guess there is something about having the charging port exposed whenever I want to use the light that just doesn’t sit perfectly ok with me.
UI
As I hinted to earlier, the UI is intuitive and simple. There is a rotary dial to select one of three lighting modes out of the front, red, a cool white throwy beam, and a warmer white floodier beam. From there, the center switch controls brightness levels with your common moonlight, low, medium, high, and turbo. The side light automatically turns on at medium when pulled away from the body and can be turned on that way even when the lock is engaged. The center switch can then adjust the brightness or turn it off and on.
Usability
As a pocket EDC light it performs well. The combo throw and flood beams are useful. The added red to preserve night vision is handy too. The feature that really sets it apart is the side light. This would make it a valuable chore/task companion. Especially when there is something for the magnet cling to.
Performance
For a light this size it can get plenty bright in flood, spot, and red mode. The side light is also nice and bright and great for a little illumination of your immediate area. The claimed maximum 1300 lumens is useful, but I don’t think you will see any jaws drop. Being packed with features is where this light finds its niche.
Summary
Overall the HD02 MINI is a solid EDC take on the larger sibling lights. The 4 in 1 combo in a quality yet affordable package really delivers. The wing light on the side adds a little extra not many lights this size can boast. The added charge indicator is also a plus. I have already begun working this into my EDC rotation and it’s earned a permanent spot there.
Check it out here at my exclusive link to get it for $39.99!
