Wurkkos HD05 Multifunction Light
Introduction.
I was graced with a new Wurkkos HD05 flashlight, and oh boy was I loving it. :joy: I was always fond of the Sofirn IF23 as a handy-dandy dual function light, with hella bright main light and wide angle side-mounted flood light (RGB+WW+CW), but the HD05 takes it to a whole new level. The HD05 has the main white beam, a UV light, and red light, on the front, and a side-mounted “wing” panel that’s WW-CW (mixable).
It takes a 21700 cell for lots of runtime, even at the rated 3100lm, before stepping down to about 900lm. It has onboard charging as well. The user interface is simple and intuitive for its main functions. It has a strong magnetic tailcap, and even a threaded hole for a tripod mount!
It’s basically a Swiss Army Knife of flashlights!
What You Get.
The HD05 comes in a simple box with plastic tray inside, holding everything. The cell is inside the light, but you need to remove the plastic insulating disc which prevents accidental turning on. Also included is the printed manual in a variety of languages. You also have a charging cable in usb-c, plus a baggie with lanyard and extra O-rings.
First Impressions.
My first impression was that this is one beast of a light! It’s solid, substantial, meaty, and just exudes wonderful toxic masculinity. :joy:
It has definite heft, and isn’t a lightweight. It might not be a comfy fit in a pants pocket, but you know it’s solid like a cudgel. It’s not cylindrical, but an oblong octagon in cross-section. Lots of grooves and chamfering make it grippy af.
A huge long wide one-way clip is screwed into the side. As much as I dislike clips and usually rip them off lights before even turning them on for the first time, this clip has such a low aspect ratio that even when squeezing the light tightly, it doesn’t bite into my hand, so I’m leaving it on!
Fit and finish is excellent. All the edges are smooth with no sharp corners or edges except for the front of the body around the lens. Those corners are a bit pointy, not enough to hurt or scratch, but definitely not rounded down.
The gray anodisation is beyond excellent. It’s a beautiful matte medium gray what I’d call Jetbeam Gray. Anyone who knows me knows I love love love the ano on Jetbeam’s Jet-I and Jet-II. Yeah, this ano is That Good.
Everything’s nice and flush, too. The little “window” that houses the red/UV emitters is perfectly flush with the body. Even the flap over the charging port is flush. The little tab on the end of the rubber flap is stiff enough to stay close to the body, yet is substantial enough to be able to pry it up easily. On so many other lights, I have to snip off that tab to keep it from grabbing on things and pulling up the flap. Not so, here.
Even the switch oozes a quality feel. The button is decisive, not mooshy. The selector ring also has good detente. There’s a little bit of siltiness when twisting it, but nothing objectionable. I don’t know if oiling it would help, or just attract dust, so I’m fine with leaving it alone.
The tailcap threads can stand a dab of lube, but the action is consistent and smooth, not even a hint of any binding or scratching.
I’ve tried to pick it apart but can’t find anything to complain about. :joy:
The Beams.
The main beam has hotspot+spill like any reflector light. It has remarkably little tint-shift. There’s not a hint of fried-egginess in the beam. No nasty corona around the hotspot, either. On its highest, everything seems pure-white across the entire beam. It definitely goes a bit green on its lowest levels, but even that’s minor.
The orange-peel reflector smooths out any rough edges in the beam, and gives a nice transition from hotspot to spill. The crenellations around the lens give a bit jagged appearance around the periphery, but unless you twirl the light when it’s on, you likely won’t notice, let alone care.
The UV beam also has a reflector-type beam. Call it “useful spill” around the periphery and a nice tight hotspot.
The red beam also has a reflector-type beam of hotspot and spill, but the hotspot is so wide as to give it an almost TIR type beam, bright in the center that gradually fades to the periphery.
The wing light is COB style, just pure flood. It makes for an excellent reading light, and the wide area of the emitting panel helps get rid of any harsh shadows.
Cold white isn’t as obnoxious as I would’ve thought, and warm white is just wonderful. It also mixes nicely to get any color temperature between the extremes of 3000K to 6000K. 3000K is great for reading, especially at night, and 4000K-4500K is nice for an area light when looking for something in a drawer, say.
Again, no complaints.
The User Interface.
Generally, it’s as intuitive as you can get. The main pushbutton is click on, click off. The selector ring lets you choose the main beam in the middle, or flick to either side for UV or red. The wing light? Just pull it open and it turns on, close it and it turns off. In fact, if you have white/red/UV already on, pulling open the wing light switches to that instead, and closing it reverts to the original white/red/UV!
Adjusting brightness is as simple as pressing and holding the button. For both red and white, press+hold ramps the light brighter, and press+press+hold ramps the light dimmer. For UV, holding just alternates between bright and dim.
From off, holding always lights up in the lowest brightness in all three modes.
Doubleclicking gets you to brightest.
When in floodlight mode, in addition to brightness, press+press+hold adjusts the color temperature similarly, between cold and warm.
The instructions are even printed on the body right under the wing light!
And yes, the wing light not only opens/closes, but can also twist, to be able to aim the light almost anywhere.
Other Features.
The main pushbutton has an indicator light that lights up for a few seconds after activation to show the battery level. Four levels are roughly in quarters, from full to empty as solid green, flashing green, solid red, flashing red, respectively.
USB charging is similar, red for charging, green when fully charged.
The light works in all modes whilst charging, including turbo! So you can use it as a reading light or area light all night long if plugged into a charger!
The light can lock and unlock via 4 clicks.
It does have blinky modes, regular white strobe and flashing red. The latter can be handy on the road in case you get a flat tire or similar. Just use the magnet to stick it to the car, and let it blink away while changing it.
The threaded hole lets you use the light on a tripod, with a camera pistol-grip, or with any ¼"-20 mount.
Wrap-Up.
All in all, I’ve been seriously impressed with the HD05. All the features are well thought-out. It’s incredibly useful with all its modes and features. The UI is simple and intuitive. And as mentioned, it’s a sort of Swiss Army Light. There are few if any compromises, as it delivers what it promises.
No, it’s not the kind of light you’d carry in a pants pocket, but in a jacket, sling-bag, etc., it’s perfect. Even just to grab it when walking the dog, working on the car, or just keeping around the house as a do-everything light, you can’t go wrong.
It’s just a great light. :partying_face:
-30-
More goodies, courtesy of Judy at Wurkkos!
Product Page:
https://www.amazon.com/promocode/A3SPC4K3F7MT97
Start Date: 2026-4-29 07:00 PDT
End Date: 2026-5-15 23:59 PDT
Code: 534ZYAOQ
