Wurkkos TS22 permanetly stuck in strobe!!!
Wondering if anyone has encountered this before. I was trying out the 5-clicks on the Wurkkos TS22 to enable the button light indicator. Then in the middle of changing button indicator modes, the light went to strobe. Permanently. Clicking or holding the button does nothing. Taking the battery out, then putting the battery back in will immediately make it go into strobe.
As long as the battery is engaged, it strobes!
Not sure what to do. Contact Wurkkos? I only got the light 2 months ago. Any way to fix it myself? Is there a factory reset?
Factory reset. Hold onto button, unthread head or cap until power stops, thread it back on, wait for it to brighten up and go dark. Besides that, I believe 13H also works.
I have had lights that have gotten stuck in different modes a few times in the past. Including recently a TS10. I could not get it to do a factory reset.
Try cleaning all of the electrical contact areas. Inside the head the center contact and outer ring. Tail cap spring, both ends of the tube where it is not anodized. Even plus and minus can be cleaned. Make sure the retaining ring in the tail cap and head is tight. (when applicable. I don’t have a TS22 to check)
Edit:
It looks like the TS22 tail cap spring sort of friction fits into a pocket. Maybe try twisting it a bit while pressing in… Just to make sure it has good contact. If you can move it a bit, while keeping it pressed in… all the better.
I use Isopropyl alcohol on a Q-Tip. Anything with visible corrosion , I use a pencil eraser first. I am not sure which part of this did it, but it fixed my stuck TS10.
When it is working again, you can lightly apply lube to the threads. Being careful not to get any on any of the electrical contact areas.
Good luck!
If you use NO OX ID it is electrically conductive…No worries about getting it on Any electrical component/ contact.:ok_hand:
Been using the stuff for 15 years. Mostly on flashlights but has many other uses like car battery terminals, squeaky car door ect.
It’s actually safe enough that it can be used on Deli equipment.
I think you need to be just as careful with something conductive as you do with a dielectric lube. Probably more so.
Insulation will just make things not work. Shorts in the wrong places fry stuff.
In either case, judicious, sparing use of lube is the best approach.
We can agree to disagree. The stuff has been used for many many years primarily on battery terminals on boats to keep corrosion from forming.
That is as electrical as you can get. No hindrance whatsoever. Nothing is going to get shorted out using this stuff. You don’t put Globs on.
I’ve never had an issue of using it on my lights or my car batteries for the last 15 years. I do put a generous amount on the terminals to fight corrosion which is always done. None of that white stuff is ever formed.
