Wurkkos Ts25 lens size
Hey could anyone help me find a replacement lens for the ts25
Not sure what happened. My wife says she didn’t drop it and she only noticed when it cut her finger.
The remainder of the lens crumbled once I removed the bezel or else I’d measure
Thanks
I make it 26.46mm. But it was a cheapo micrometer I used, so I’d guess 26.5mm by 0.97mm thick, call it 1mm. It does appear to be a coated lens.
Thanos for the quick answer, Looks like kaidomain has a 26.4x2
I’ll have to keep looking and send wurkkos a PM.
The extra millimetre in thickness shouldn’t be much of a problem, it’ll just make the light a millimetre longer. The gap between the fins and the bezel doesn’t really become obvious till it is unscrewed maybe 3mm.
You could try emailing Wurkkos. at wurkkos@foxmail.com
I just saw someone on Reddit who tried Convoy S21d lenses in a TS25 and said they were a direct fit. posted pics too.
From a quick look at the Reddit, it appears he is talking about the TIR optics rather than the glass “lens” in front of the optic.
Yes the reddit was about the optics, but suppose the lens could be equivalent.
I sent message to wurkkos yesterday but I haven’t heard back yet. Either way seems it’s going to take a month to get a replacement lens.
That’s a pain. I had a look through my stash of light bits but don’t have anything suitable knocking about.
https://flashlightlens.com might have something suitable. This UCL Lens - Flashlightlens.com - Online Store might work the 26.8mm diameter might be a little large. The extra thickness I’d regard as a bonus. Borosilicate glass is also a lot tougher than plain glass.
Sadly, it wears to be a pretty unique size which is always a bit unfortunate.
Actually, it is pretty close to the front diameter of a P60 dropin based light. Time to dig out the Bag of 200 Lights and see if any of them will fit. Nope, they are 30mm or so in diameter.
Edited to fix sticking key trouble. The dog’s been drooling on my keyboard again.
The D4V2 glass works just fine. It is less than a mm different in diameter and double thick. The s21d optic + the D4V2 lens is a little thick but you can use the stock o-Ring. A D4V2 o-ring is slightly thinner. It depends on how wet you plan on getting it, but it seems to be just fine.
I’ve got a couple shelf dwellers I’ll give one a try. Thanks.
