Triple XP-L HI v2 1A on Noctigon MCPCB
Carclo 10507 TIR optic
ARC glass
18mm x 8mm copper heatsink
17mm MTN FET driver
Forward clicky switch
Lockout-able
6x2mm green tritium vial
GITD powder & resin bezel points
Filed out body for 16500 cell
length - 101mm
Width - 22mm
Max – 2000lm OTF
Beautiful work, as always! :+1:
Awesome mod!
What did you use for the spacer?
I have a cube as well and really want to mod it into a mid power triple high CRI nichia, but I’m having a real hard time to remove the bezel.
Thanks guys.
I used copper bar stock for the spacer.
It’s a tricky light to make a triple as everything goes in the front so i soldered the spacer to the pill and cut in three notches in the spacer where the holes are in the MCPCB for the legs of the optics for screwing the unit back in. Heat the bezel some then unscrew with long nose pliars or something which fits. Put thick tape over the glass.
Thanks! Will try that and let you know. I had his light for a while but realized that while it was pretty in stock form I would never give it any real use. since I don’t have any metal working skills I might have to stack Copper mcpcbs of different heights, let’s see…
Cool. It’s the 16500 cell mod that makes a huge difference though. The tube is wide enough in the middle but has the lips at each end. I filed them away by hand and it was a total bear but worth it.
Hey, I got a cube!
Mini mule cube, looks familiar…
