tatasal
(tatasal)
38
Well, pending Mr. Barkuti’s more high-tech suggestions, this is my primitive solution to the problem:
Since I took out the OEM 1500mAh cell that was utterly ruined by over-discharging while in storage due to (I believe) parasitic draw or leakege, I put in a brand-new Samsung INR18650-25R cell…soldered wires in place of the original cold-soldered metal strips, installed a long wire connected to the (-) side of the circuit and put a connector to interrupt the electrical flow when not in use…talk about a true mechanical for electrical lock-out haha… I tested the unconnected wire with my DMM and it showed 10.54mA.
So, if the new 25R cell will have a net output capacity of 2350mAh, it will drain the cell completely in less than 10 days! (as explained to me by my friend, TA)
I welcome members’ suggestion for a ‘sleeker’ solution.
