I am having a tough time removing the driver from my xintd c8 v3. I solder wicked the solder from the pill and the drivers edge and tried to use an exacto knife to scrape along the edge but It still stuck in there. Any help would be appreciated.
It may sound like the exact opposite of what you should do, but add solder back to one of the spots where it was originally. Only one side. Pull/pry up on that side of the driver, while melting the solder with the iron. The problem is you aren't going to melt the solder that's left behind just by holding an iron against the driver and the pill, it works much better if you're melting solder that's in direct contact with the iron. Once one side is lifted up the other side will usually break loose.
Comfy's advice is good. Add more solder to the existing solder then solder wick again. I'm not sure what kind of solder they use when they assemble these but it melts at a much higher temperature than even the lead free solder I have. Mixing some fresh solder and flux with it really helps a lot.
