Just brought two XinTD C8 V5’s, one xm-l2 u2 and one xp-g2.
Out of the box it looks and feels brilliantly made; unlike some had reported, the LEDs on mine were perfect centred.
However first problem:
Poor connectivity with cells
My NCR18650PF’s give a really poor connection while in this model, meaning I thought I could not use them without adding a conductive pad at the end. I found in my Convoy C8 perfect connection.
So naturally I tried my protected cells, but found it had the same issue! Both flashlights flicker while on, and 60% of the time the on button doesn’t work at all with.
Is this a bad connection with the batteries or a short somewhere along the line?
If you can take the bezel and lens of and unscrew the reflector 1 turn being careful at the same time to make sure you don't touch the reflective surface. The reflector could be shorting on the led wires.
Haven’t had too much chance to try it out. It gets dark pretty late here and I have had work. I’ll bring it with me on the way back from the pub tomorrow night and let you know. It’s a very, very tight spot.
Just got mine in the mail and am blown away at the quality. The green o-ring in the head is gorgeous and needs to be a standard amongst flashlight manufacturers these days. I haven’t had a chance to see how far it will throw at a distance, but at 25 feet, it has a perfectly tight circle.
I compared it to my solarforce L2 little xml2 drop in flashlight and it blows it away. Much much brighter and a PERFECT beam spot.
Didnt have any trouble with it flickering and I’ve tried protected and unprotected cells in it so it must be a fluke. Also, the LED is perfectly centered. Awesome MUST HAVE light!
XInTD C8 is only in SMO reflector. I say get the convoy C8 for the nice OP reflector its more versatile and have a smooth beam OR the XinTD if you want to see far ahead for outdoor use.
I ordered a couple of clearance XinTD C8 V5 from IOS for $15 each. He’s clearing them out because of off center emitters. Re-centering the emitter should take me a couple of minutes.
If you want to order one piece, enter 15 into the add to cart box. If you want two pieces, enter 30.
When paying, note in comment box …one B-grade XinTD C8 V5
Just a little info on how these end up with mis-centered LEDs... with the star soldered to the pill, and the reflector threaded into the top of the pill, once it's soldered it can't move. The light doesn't use a centering/alignment spacer but just an adhesive backed flat insulator but with the star locked into place not even adding a centering ring would help. The star has to be reheated and nudged in the right direction, and then checked in the reflector, and do it again if it's still not right. Be aware that the amount of heat needed to melt the solder under the star will also melt solder under the LED, so you have to be careful about bumping it when moving the star, and also careful about how much heat you use. It's not that hard to cook the LED.
An alternative is to apply heat until the LED is loose, then remove it and set aside, then keep heating until the star is loose, then remove it too. Sand/file the solder down smooth, then reassemble with screws (or without screws, if you want to add a plastic centering piece to align the LED & reflector). Screwing the reflector into the pill can give enough clamping force to make the thermal paste work, if you get it tight.
