XinTD c8 v5 setup
Hello im entrusted in buying a xintd c8 v5 from ourdoor but i would like a ask a few questions.
First whats the difference between the default XM-L2 U2 1D and the optional CREE XP-L V5 2A LED both are cool white but which is going to be more efficient or brighter.
With the different mode options would i have a more powerful light if i picked the simple 1 mode thats says its 3.06a vs a 3 mode set up? Dose it have memory if i wanted to stay on high every time i clicked it on ect?
Also could u explain the difference between the default forward click and the reverse click tail switch?
Im basically looking for the brightest combo i can build…ill be using panasonic 3400 unprotected 18650s.
Im also open to other options for very bright 18650 lights if u have any suggestions in the same size/ price range thanks!
Hi Dugan661,
The XP-L will be slightly brighter than the XM-L2, but the difference will be barely visible, if at all. The 1-mode will be no brighter than the 3- or 4-mode on high. The only reason I can think of to have only one mode is if you are going to use the light in high stress situations where it is critical that the light always come on in high, like law enforcement. The XinTD c8 has on-time mode memory, which means that as long as the light is on for more than 3 or 4 seconds in a single mode, it will remember that mode the next time you turn it on. Forward clicky means that slightly pressing the switch without fully clicking it will activate the light. The advantage is that you can momentarily turn the light on silently, but the disadvantage is that you cannot change modes with the light on once you have clicked the switch. Reverse clicky requires you to fully click the switch to turn the light on, but you can just tap the switch to change modes with the light on.
The XinTD c8 is a great light, but if you wanted other options, you should check out the BLF Edition Eagle Eye x6 Group Buy:
Welcome to BLF!
Wow thanks for the info! That
Group buy looks like an awesome light… But its only 350lm? It seems to use the same led and 3a +/- driver as the c8…why so much dimmer? Also im a bit confused on how to order and the options on that light…
No problem, just passing on what I’ve learned from BLF! :smiley:
Regarding the group buy x6, don’t ever believe the lumen claims of Chinese manufacturers. Seriously, they are so rarely right……. (bangs head against wall). The XinTD is one of the few that is in the ballpark. The BLF edition x6 will be a little brighter than the XinTD c8 (BLF x6 will be driven at 3.5 A). How much brighter, nobody knows exactly right now, but Banggod has sent out pre-production samples to four BLF members, so we should have some hard and fast numbers soon. It’ll be in the 1000lm range. You can’t order right now, just post on the thread how many you want and whether you want neutral white or cool white, and that will reserve you a spot for when the production run is completed.
the first light I put together myself was a convoy s2 host, xm-L2 t6 led on a noctigon star, and a qlite 8*7135 driver. I got all of those pieces from RMM at mtn electronics for less than $20. all shipped from the US so you won’t have to wait long. I got the thermal paste at radio shack. blows away my fenix pd30 and has a nice combo of flood and throw — I say it has throw but it’s not nearly as tight as the pd30 beam but makes up for it in brightness. you can also change modes without disassembly by using a pencil to draw on the driver’s stars— this light is small enough for edc and in the stock 3 modes it covers pretty
much every need. I recently added the moonlight mode for middle of the night bathroom or thermostat trips without waking anyone.
The XinTD C8 V5 is a fantastic light!! It’s very nice quality and comes with a Noctigon directly soldered to the pill as standard!
If you are not interested in lower modes the other alternative would be to run the light in direct drive. Although you lose all safety parameters so if you went that way I would recommend using protected cells if you are new to all this and the other thing is it will warm up fairly quickly. I run my XinTD C8 in DD off of a Sony VTC5 cell and it is one hell of a light for it’s size.
I happily recommend that light to everyone who is new to proper LED flashlights.
The XinTD C8 V5 is absolutely my favorite flashlight in existence. (sub $50)
I would choose the XM-L2 instead of the XP-L.
I also prefer NW tints, for a very slight tradeoff to maximum brightness. (This wasn’t previously my view, but I eventually “saw the light”)
Any reason for this?
It handles high current better.
I couldn’t agree more. It’s my “go-to” light anytime I reach for a flashlight. You could buy any combination of modes, clicky, or type of LED and you’ll be blown away as I was. The quality it astounding!
I bought the xml2-u2 with 5 modes and couldnt be happier. The only thing that gets me is the memory. You have to keep it on that mode for about 5 seconds before you turn it off, if you want it to go back to that mode when you turn it back on. I wish it had been instant, ie the light will revert back to the last mode used even if it is only used for a split second. BUT, that’s more of a personal preference than a gripe.
Make sure you get some good, quality batteries in there and you’ll have the best sub $50 light in my opinion!
