XinTD c8 vs Convoy c8?
From a DIY host form factor, building on this host with the same emitter which one is or was a better Host? i read somewheres the XiNTD c8 has ugly rings in the beam which doesn’t make seeing how it is a OP reflector… Lets use the XML2 as an example is it a good choice in this light? has anyone used something bigger…MTG2 or XHP50, 70?
I have built XHP50 and XHP70 into Convoy C8 “with removable pill” just want to know how well the XiNTD design is…is the threading just as good as the convoy…or i it better? how well does the reflector and pill thread together? does the reflector thread into the host too or just the pill into the body?
The XinTD is far better than a standard C8—heavier brass pill that the reflector threads into nicely-the reflector is smooth and definitely several cuts above a standard C8- then the pill threads into the host just like a regular C8—the nice part is you can focus the light without putting the bezel or lens on—the entire host seems thicker and heavier—I have several—dome on works perfect— a XM-L2 4C and a 2B are right up there with some Fiat Lux lights I have—I also have a XM-L2 1A dedome Richard built for me —It’s slightly ringy wall hunting—this light has an older LED with one of the first generation fets—it pulls 7amps and throws 160,000lux—a flashlight lens UCL is a must—transforms these past the modded Eagletac SC200—I would just like to know who came up with that wonderful color HaHa
I have a convoy c8 version 2 with a mountain electronics fet dd driver with a dedomed xml2-u4 and I thought I had a bright c8 that could throw untill friend shows up with his xtnd c8 with a 3.04 Amp qlite drive and a xplv6 from international outdoors and he blew my light right out the water in brightness and throw and he spent less by the time it was all said and done.
What reflector do you have—did you braid your switch spring
How far will the XINTD C8 V5 xp-g2 S4 throw in comparison to these lights?
smooth on both and yes braided springs and Samsung 25rs he was using a Panasonic 3400b protected I’m telling like any other people told me those xitndxtnd are very efficient and kick arse lights I didn’t belive it untill I ssaw it myself and I imagine the xpg2 will throw a lot more than xpl s maybe they do auch better job focusing I tried adjusting reflector to get the best beam but it was nowhere close as the xitnd
Hey Mr. Nobody
You got me with the fake bug.
Touché
:slight_smile:
Yes my kids really do like that bug too!
lol I don’t know Iam slow I’ve seen it and I keep falling for the darn thing
That bug drives me nuts too
bug driver?
I can’t say how the stock convoy does as mine is a custom built from RMM (Richard) at mountain. I can however tell you that the stock XinTD C8 V5 XP-G2 S4 2B does a very good job right out of the box and I get around 300 yards of useable light from mine (not small objects) but large dogs, deer or bigger. It is not at all “ringy” and has a pretty tight hotspot with good spill. I would say if you modded this light it would be an outstanding performer. Has great fit and finish and best threads I think of any light I have. I have thought about getting it modded but it is so well built and does such a good job stock I am almost afraid to change anything about it. Here is a link to a few beamshots of mine. Also if you scroll just a tiny bit down on the page, the distance is at the bottom of each picture.
beamshots and very impressive congrats on a great light
Thank you, Still learning as I am pretty much a newbie, but I am tryin to improve and learn as I go. This forum and people here have been very helpful.
Wow! VERY nice performer and VERY useful beamshots! Thanks so much!
