XiNTD X3 XHP50 12V ?
So I got the good 3x AA insert for this light. So how does 3x 14500s which will be 4.2 times 3 = 12.6v
A XHP50 on a 20mm 12v noctigon from RMM
A 20mm DD Fet ZENER driver from RMM
I am VERY clear of the little dimple inside the head on the MCPCB shelf (NOT AN ISSUE)
Does this build sound silly?
Yes very silly! The runtime will be super short…. it’ll run on high and the battery is depleted so fast it doesn’t have time to step down I think
My other idea is a XHP50 6v and same fet driver using two 18350s I was wondering if the throw would be just as good with the xhp50 as it is with the XML2 that's in it now
If I’m not wrong the die size of the xhp50 is 1.2x larger than xml2. So throw will be a wee bit reduced. But there will be the issue of a donut hole in the beam. However if you wanna use 18350 it’s better to replace with xpg2 or xpl
well the donut hole isnt much show on my Convoy M2 build which uses 2x18350 has XHP50 + DD fet driver.
Sure white wall search with the light yields a ugly black cross but outdoors “In the wild” there is no notice of this dark spot
Well whatever floats your boat! :slight_smile: but runtime on 18350s will be pathetic I must warn you
is there a extension tube that fits this light?
I’ve never seen one for the X3 much less those who requested it
How about hd2010 extension?
Nope… Normally those lights are made as throwers not max lumens…
Fun idea, but you really would have to stay on top of low capacity cells in series. I've had too many 14500's fail on me. I wouldn't want to be near such a light when in use.
I am thinking i will just keep it how it is and run a FET with a XML2 or XPL.
The issue i am concerned is with an XP-L and its beam pattern. Since its a smaller die then the XML2 which the reflector is cut for I will ASS’U’ME it will have a much smaller hot spot with more throw?
XML2 5 x 5 x 3.02 mm
XPL 3.45 x 3.45 x 2.68 mm
I am choosing XPL over XML2 because of tint choices
An idea is the NEW 2015 XPL dedome LED in this light with its large reflector should YIELD one hell of a thrower
The dimensions you list are the substrate size for the emitters. The actual die size of the XP-L is exactly the same size as the XM-L2
Get an XP-L high intensity if you are after more throw than XM-L2. Otherwise XP-L and XM-L2 are pretty much the same.
As the emitter needs half the amprage at 12v then at 6v, and since 14500 and 18350 have about the same capasity I think 3x14500 would net a more usable run time for the light v2 2x18350.
I think the the 3x14500 or 4x14500 might do well in a MT-G2 headlamp where max brightness is not the top metric but lots of flood and nice color are desired.
.02
Yes! that’s what I want.
