someone already tried one?
@ Cree: XLamp XP-E2 Torch
Rated at a higher maximum current than the XP-E LED, with simplified color binning that is optimized for portable-lighting applications, the XLamp XP-E2 Torch LED is designed for a wide range of mainstream portable-lighting applications. The XP-E2 Torch LED delivers 20% higher lumen output than the XLamp XP-E LED in the same XP footprint.
XP-E2 Torch
Size |
3.45 x 3.45 mm |
| Maximum Drive Current | 1.5 A |
| Maximum Power | 3.5 W |
| Light Output Range | 360 - 456 lm |
| Maximum Efficacy at Binning Conditions | 103 lm/W |
| Typical Forward Voltage | 3.5 V @ 1.05 A |
| Maximum Reverse Voltage | 5 V |
| Viewing Angle | 125 ° |
| Maximum Junction Temperature | 150 °C |
| Binning | Torch |
| Thermal Resistance | 9 °C/W |
| Temperature Coefficient of Voltage | -3.9 mV/°C |
| Maximum ESD Withstand Voltage | 8000 V (HBM per Mil-Std-883D) |
| Reflow Solderable | Yes - JEDEC J-STD-020C-compatible |
| RoHS-Compliant | Yes |
| REACH-Compliant | Yes |
| Package Size | 3.45 x 3.45 mm |
XP-E2 Size |
3.45 x 3.45 mm |
| Product Options | White Color |
| Maximum Drive Current | 1 A |
| Maximum Power | 3 W |
| Maximum Light Output | 283 lm |
| Maximum Efficacy at Binning Conditions | 137 lm/W |
| Typical Forward Voltage | 2.9 V White @ 350 mA |
| Viewing Angle | 110 ° |
| Binning | 85°C ANSI |
| ESD Classification | Class 2 (HBM per Mil-Std-883D) |
| UL-Recognized | Yes - Level 4 Enclosure Consideration |
