As title says, need free shipping to uk anyone know where i can find one?
thanks
thanks
Doubt it's U2, but here you go.
https://www.fasttech.com/products/1609/10003889/1574601
Keep a list of vendors tht are convenient to you.
I’m not sure if shipping is free to UK, and also they don’t specify the board thickness, but FT has these:
Says worldwide free shipping.
Are these shown definitely 1mm thick star? I need that size specificly
Sand it down if you need.
There's no such thing as exactly 1mm. You could spend eternity trying to achieve that, but unless you are dropping it down to absolute zero, an atom will jump.
Okay i didnt mean that precise but thinner than most 1.6-2mm stars id rather buy it 1mm than sand it and make it wonky ![]()
i said specificly not exactly btw
No access to a sanding belt?
Not really wouldnt it be easier with a peice of sand paper on a very flat surface?
Info from this thread (with thanks to CRX),
says that the XM-L2 is 3mm high, the one from FT linked to above is 4.7mm high, so the base is 1.7mm thick.
Have fun filing/sanding ![]()
Cheers David
Thanks for that, looks like i’ll have too!
