XP-G2 P60s
I just built my first one of these, with a cool white XP-G2 R5, on copper, with a 3.04A 105c, with a small-opening XP-G/XP-E specific reflector, and WOW. If you haven't bothered trying this setup before, DO IT. Very, very nice. Nice proper flashlight-colored beam (i.e.: not yellow or green - it makes my other XM-L2s look like ringy icky-colored garbage), really tight hotspot, even tighter than a de-domed XM-L. Going to try one de-domed next...
p.s. Wow! :O
this emitter: http://www.fasttech.com/product/1287509
this empty drop in: http://www.fasttech.com/product/1208506
I built one in 3D tint, but on aluminium, only 1.4A and the OP version of that reflector. It is now my favourite P60 drop-in, the efficiency is as good as my XM-Ls and the throw/beam/tint is fantastic too.
Damn you. I just placed a FT order last night. Now you’re making me place another.
Seriously though. Thank you for the report. I probably would never had considered the XP-G2 otherwise.
EDIT: How can you tell the tint from the web page?
EDIT2: Opps, I just noticed the calvin range. I’m good.
Thanks for sharing. I have basically the same plans (but not with CW) as you described in OP. I ordered two empty P60s with XP-G reflector on Monday.
I will not bother to file down one of my few 20mm copper boards though. I guess you did yours for this P60? :wink:
Give me a month or more and ill get there… :slight_smile:
They are fantastic. They love the amperage (on copper, anyway) and seem to make a lot less heat than a XM-L at the same current.
I think all my single cell lights will get converted to XP-G2s, and reserve the XM-L2s for multi-cell lights that can drive them harder. Seems like the XP-G is just a better match for the P60 reflector dimensions.
I've been planning this build with a neutral white XP-G2 and OP reflector. I was hoping for quite a bit of wide bright flood, sort of like a nice XM-L, but driven less for similar output to get more runtime.
What tint would you say FastTech's XP-G2 is? 1C? (And I see it's sold out now.)
-Garry
How does the XP-E/XP-G reflector work compared to the XML?
How would you describe tint?
For those who are not aware, and just want cheap XP-G2. This/these arrived quite recently in several sizes:
http://www.fasttech.com/products/1/10001905/1311501-cree-xpgbwt-xp-g2-r5-1a-472-lumen-6500-7000k-led-e
Well I'm an anti-tint-snob snob (these are flashlights, ffs), but the one I used just looks white, compared to XM-L2 T6 C3 (yellow) and XP-G2 R5 3D (yellow-brown incan-like).
I wished I could be anti-tint-snob and enjoy 6500K emitters for general use. Having max output, and generally lower prices, no issues finding cheap emitters or in general the emitters you want… You lucky ba#£… :wink:
But I am a sucker for lumens and great prices… So, I ordered one of those cheapo XPG2s and a SMO XP-E(/XP-G) empty P60 just because… Lots of throw in P60. And just because… SO CHEAP…
…and so that I can compare it with a NW (XP-G2) in the 4250K range with OP reflector.
I just built the same P60 module from FT , but OP reflector with XP-G2 3D and a 1.75A driver. It’s pretty nice.
Thanks Comfychair, I have some of those modules in smooth. I’ll try swapping reflectors, and see how it goes. I was a little gun shy of the smooth reflectors after I got one from Custom Lights that had the ugliest, ringiest beam profile I’ve over seen.
I think the nice beam pattern is down to the emitter, somehow. Any combination I try, the XM-L has, not really rings, but multiple bands. The XP-G even in a bigger XM-L reflector has just a tight hotspot, and then an outer spill that looks the same from the hotspot all the way out to the edge.
I love xp-g2’s! built two so far and both make me very happy, I may have to try one in a p60 sized light next, I do suggest fitting one in a really big reflector though, my l2 is one serious thrower. :bigsmile:
I usually buy OP for general use. Always nicer beam… Especially if the emitter is not 100% perfectly centered and the reflector is not very good.
But once I mess up tint with CW for more throw, I can mess up with SMO for max throw too… :stuck_out_tongue:
I’m always a little leery about trying an XP-G in an XM-L reflector. I’m afraid the smaller footprint of the XP-G will give off some kind of a screwy beam profile.
Impossible to do with this combo, the corners of the LED fit exactly in the reflector opening. Focus is best with as little insulator thickness as you can get away with. 'None' is the best, if you can do it without shorting anything.
(also too: LOL at 'voltuge') :X
It doesn't, already tried. XP-G in a XM-L reflector works better than the XM-L in the XM-L reflector. Not exactly quite as good as the XP-G in the XP-G reflector, but still better.
Had Vinh on cpf custom make OP p60 xpg2 cw @3.5 on copper, great results.
No tint shift with good spill and throw, my favorite dropin as far.
I’ve put 2 in xm-l reflectors so far. on the l2 I first tried without the xm-l locating disk, ring city, I was really upset, used the xm-l locator (completely misses the die)
the rings are created by the camera, in reality, its as smooth as the beam on my d5.
Comfychair, that picture is even more exciting than the mtg-2 plan, and I agree lol at voltuge. :bigsmile: do it!
My experience is that in P60’s if you want a wider hot spot/flood then use a XML if you want a throwy/tighter hot spot use a XPG2. Even the xpg2 in a OP reflector has a tight hotspot versus’s a XML with smooth reflector…
