I’m still learning about LEDs, so there may be some rudimentary questions.
I’m also not sure if this is the right forum to ask for advice in; if it’s not, please let me know.
I’m looking for LEDs to put on an RC plane. I have a XM-L2 flashlight, and my idea is to recreate the flashlight electronics and put in on the RC plane. I want to have 3 LEDs (one white, one blue, and one red) blink in a pattern visible from the ground, a distance of about 50 meters. Size & weight are important, so a 3-Up configuration is very appealing due to the 1” lightweight PCB footprint. I’ve done some research, and I have some questions about what will work with what I’m trying to do.
Here’s a summary of everything:
- Do the XP-E2 royal blue and red have enough throw/output to be visible from ground during the day? For the white, I was planning to use 70-cri XP-L, and I think it will show since it is similar enough data-wise to my XM-L2. I’ve read that blue and red E2s have great throw, but their reduced lumen output worries me. If not, what other color LEDs could work? The XP-G3 royal blue and red have higher lumen outputs on the datasheet, but their reviews are glowingly negative. I also don’t know if they are compatible with a triple PCB.
- Would the XP-L still be luminous enough with 1.2 amps? RC plane rated batteries are a limiting factor. The batteries I currently have are 1200mAh, 7.4V Li-po (Amazon.com). Since the 3 LEDs would blink in an alternating pattern, I was planning to use just one battery and wire the diodes in parallel. This isn’t necessarily a problem for the E2s, but it would significantly reduce the XP-L’s output with a 1200mAh battery.
- Since the LEDs would be blinking no more than 1 second a time, is a heatsink necessary? This is a shot in the dark, but a heatsink would add weight which I prefer to avoid if possible. The blinking pattern would only be turned on for 1 minute and off the remainder of flight time. In addition, the LEDs would be located on the outside of the aircraft, so heat dissipation would increase with the 50feet/sec windspeeds. If a heatsink is necessary, what are some lightweight heatsinks I could use?
- Do I need a lens? A lens would increase drag on the aircraft, but it would be worth it if the lens significantly increases throw.
- Ideally, I would want all 3 LEDs on one PCB as mentioned before. However, if each diode on one 3-Up PCB won’t be visible from the ground, I would be open to having 3 3-Up LEDs. In this case, what combination of diodes would be best for the colored (blue and red) 3-Ups PCBs?
Any advice/information would be helpful. Again, I apologize if this post is outside the scope and/or purpose of this forum.
