18G wiring between MTN-20DDM and mcpcb. 30A efest 26650 battery. I wouldn’t think there’s any bottle necks, what could cause the XPL Hi to only draw 2.3A? Was hoping for 5-7A.
Edit: I believe the firmware is bistro if this helps.
Are you using a multimeter to measure current draw?
Do you have a luxmeter?
If so what does it read?
edit Are you sure you’re using Turbo?
If it starts on low, use a medium tap to go to turbo
The UNI-T voltmeter/amp meter. I’m measuring amps at the tailcap.
