Xtar SP1 usability and function view
This is one small charger, This new charger from Xtar is about the size of a marker or a lipstick.
Xtar have already produced a few of these kinds of smaller form chargers and they are mainly focused on mobility and to be used as an emergency phone charger. One look at SP1 from Xtar, the item that hit me was that the fonts were so small that I had trouble reading the text, or it could just be me growing older?
First impressions don’t always count as I found out later that this is a great charger! This is one of those chargers that Xtar got right much like VP1. This is a one battery charger which only uses AC as input. The spring like Xtar charger of late is functional and gives easily. I did not have to spray any lube on it. The build is solid and feels tough.
What I like: It lets you choose settings and takes the automation out of it, in this day of guessing the type, charge and Voltage (and getting it wrong most of the time this is a boon!). This also means that this kind of charger is better suited for someone who knows a bit about the type of battery they are charging and a bit of characteristics about it, in other words a battery nerd! My take is if you cannot automatic detection / termination right, put me through some hoops and let me choose more and configure more give me those buttons and levers and I will be happy.
The charger itself is a one Lithium battery charger, the difference here between this charger and say something like MC0 is that it takes AC input for charging and it’s output uses USB. I think that XTar did a good job with this charger in terms of construction as well as functionality. This charger reflects a company which realizes it’s strengths and knows about it’s devices short comings as well with a good grasp on the available technologies. Do I wish that this charger can charge NiMh as well ? Of course, but my thought is if it cannot be reliably made, I prefer that the charger just focus on what it does best. So what can it charge ? Well pretty much if you use Lithium batteries, then this charger can help you, the only form factor that it does not support is 10440 batteries. Xtar seems to have gone back on it’s focus on making everything automated with this charger where all of the functionality of this charger is left to be chosen by the user via the flip of a switch. While there are so man choices with this charger, it seems to be lacking a 0.25A setting for charging. Personally I won’t really miss a USB input for charger as I really think that it takes too long to charge a battery using that method. For all intents and purposes this is a very good charger, just the few points I would really take away from it is the text on the charger itself is insanely small much smaller than any normal eye can see. Also, for beginners to Lithium batteries who happen to stumble on this charger would be hard-pressed to know exactly what are the settings best to be chosen for their batteries. This might limit this unit to the battery geek crowd as I have mentioned before.
In terms of charging this charger works fast with the right chosen settings without producing too much heat. At the maximum charging current, the charger does not feel hot to the touch. In terms of USB output for the battery charger, it can charge up my fully depleted iPhone 1.5 times using 1 fully charged 18650 battery. This is quite good.
One other thing that I am not so crazy about is the battery holder or the lack of it. If you want to use this as an emergency charger for your iphone just make sure that you always keep it facing up or the battery just might end up tumbling out. Perhaps a small plastic knob can be used to keep the battery in place Xtar ? As a smaller brother to SP2 this totally lives up to the legacy!
All in all I am very happy with this charger 5 out of 5!
Charger graciously provided by Xtar for review. For a more indepth look check out HKJ’s view on the charger.
