teacher
(teacher)
43
I just now saw this thread. Impressive review, thank you!!
The floody version of this light SC700Fd (frosty lens) became available April 30th.
http://www.zebralight.com/SC700Fd-21700
will34
(will34)
45
Has anyone tried Lee zircon or the regular filters with the SC700D? I’m tempted to buy a 24x24” sheet of the zircon 803S to get rid of the green, which is the only imperfection with this light. I think it puts out lots of light to easily compensate for the 20% loss.
TheAuditor
(TheAuditor)
46
I have an issue with this light regarding obtaining low mode from off. I press and hold and generally miss low and go straight to medium, and blind myself when using the flashlight at night. I just can’t get the timing right so that I can reliably select low output. Too short a click and 3000 lumens, too long a click and a few hundred. Am I missing something?
emarkd
(emarkd)
47
This was a very common complaint about Zebralight’s UI for years. It takes a lot of practice and muscle memory to get the timing correct, and the only answer was to practice and practice. HOWEVER, times have changed and the UI has been updated, including in your light. Its now fully programmable, so you can set short-click to low and long-press to high, for instance. Or whatever you desire. I think a lot of us make that change in our newer Zebralights - I know I do. If you’ve lost the programming instruction sheet there’s a pdf on the website — SC700Fd 21700 XHP70.2 Floody Neutral White High CRI Flashlig
Yeah, I used to have problems with timing when I got my first Zebralight. Years later, and several Zebras later, I haven’t had that issue in a long time.
Even so, I programmed one of the groups for my “middle of the night” modes. They’re all moonlight levels, so even if I screw up it’s still very dim.
TheAuditor
(TheAuditor)
50
I have a number of ZL flashlights but this one seems to have the shortest click and hold. Still I do really appreciate the programming modes. Very nice.
Geronimo
(Geronimo)
51
I know this is an older thread, but there isn’t much showing up about this in the searches. I have and love a sc64w hi. I am looking at this. Is it remotely pocketable? My zl disappears in my pocket , this one is a half inch broader. Also how is everyone liking theirs?
You might want to try the SC600w MkIV Plus. Its size is in-between the SC64 and the SC700. Still quite pocketable. 2300 lumens, so not quite as bright as the SC700d, but close.
The SC700d is an overall very decent light, i enjoy the well regulated modes, the thermal balance and the proper runtimes (21700 50E). I use it mostly for tasks around the house and also for nightriding mountainbike on the handle bar. But pocketability is not a strength of this light, of coure in a pocket of a jacket will never be a problem to carry it, but for a jeans pocket is it definetly to bulky for any kind of EDCing.
I have also the SC64w Hi (which is my most used light ever), regarding pocketability, it is definitely in another league. For more output then this and still compact size, the SC600w plus mk4, which was proposed by WalkIntoTheLight is a good choise. The SC600 format ist still very compact, is a bit better thermal balanced and is not to bulky for a jeans pocket.
Not sure if it was already mentioned in this thread, but here is another nice review by 1Lumen.
SC700d
Geronimo
(Geronimo)
54
Thanks for the response, it sounds like I thought it would be. To big and maybe more of a ‘house/truck’ light. I do love my sc64 w hi as well. I will look at it the other light. That is a good review you linked. Pretty soon we will be debating on the new ZL headlamps coming out, the a6 and a7. I asked if they are 21700 series and I think they said they would be.
This sounds interesting, its some new information for me, where do you got this from? What else do you know about the new Headlamps? With 21700?
Geronimo
(Geronimo)
56
I messaged ZL about it when I was looking at Fireflies pl47 gen 2 ,but their qc seems horrible so bought a ylp 2m cri and maybe soon a zl. I asked if they had plans to release one with 21700 battery , they responded soon a 6a entry level one and a few months later a 7a , not sure but their page has a 6a listed on the compare charts but it says 18650. That’s all I know.
Geronimo
(Geronimo)
57
So what other light overall would you consider the better or equal? Waterproofness , toughness dependability, then brightness ui etc.
Well it’s hard to say what light is better or generally good one. As always, it dependent on your needs or your wishes/expectations on a light. If you got already a good one you are satisfied with, than ask your self, what would be nice if this light would do better. More runtime, more output, more throw, flood, smaller/bigger and so on. Depends on the needs, different lights come in focus.
I’ve got 5 Zebralights and all of them are really well made quality lights that I can rely on in all conditions of use. I was often swim in a lake with a zebra in my hand, it’s a nice effect to illuminate the water from underneath.
Zebralight has a few different variations of lights, but not all different needs can be covered by them. There are so many different manufacturers with good quality lights on the market, which are also very good. I do not know all and can not generally judge which are better or equal.
The Zebralight UI is fine, but i also like the Narsil/Anduril UI.
Yuck. 21700 in a headlamp? Too big and heavy! Even though Zebralight makes among the smallest lights, I don’t think a 21700 form could be made small enough.
While I like Anduril, I find it more of a “toy” than a serious light. Also, the whole D2 meltdown with it made me no longer trust it; it’s just too complex to code safety into the light.
