ZL H501 flickers on High
I bought a ZL 501 second hand and I love every minute of it
I usually use the LO or MID setting but when I do turn it up to HIGH it begins to flicker. It’s random and not very noticeable but it’s there - more annoying than disturbing, really…
First I thought it was only because the battery was dying but now I put in some fresh Duraloops and it does the same.
Has anyone experienced this?
thanks,
-Greg
Hey svegs. I would say it needs a good cleaning. My new SE-1 was doing the same. Cleaned the threads and all contact points and it works like it should. Good luck.
Keith
Don't use it on high .....
great lights
501 is one of my favorites
Z.Light 8320 Sterling Street
Irving, TX. 75063
USA
maybe it's worth giving it a ride if you can't fix it ..
Whats the worst thing they can do ?? Send it back to you ?
EDIT* ...whoops ... thought you were U.S.
@Keith Thanks that could be it, I didn’t clean it when I received it so maybe that is the reason indeed
We are just talking wiping it clean with a dry cloth / brush, right?
@Boaz LOL being a non-tech person myself that was my instinctive solution too: stick with lo and med :slight_smile:
thanks for the address, might come to that if cleaning does not help
although from Europe they might prefer I send it to China instead - will contact ZL if problem persists
sveqs you will need isopropyl alcohol.
Keith
roger that
will get some at pharmacy on Monday and report back to you
thanks again
-greg
