before new year was there i decided to clean my failed flashlights and found the ZY-T08 i tried to mod with a dedomed xml2 u2 on copper and a 105c driver @ 4A.
i got the light togheter in the past but for some reason the driver skipped modes, i could not get the led to focus and after some trying to make it work the contact board kept shorting my batteries and the reflecter was worth nothing. so i decided to put it in the “failed box”.
being a flashoholic i ditched the cleaning idea and went with the modding idea.
after some digging around i found a old driver from the TR-J19. so i decided to turn the ZY-T08 into a series light that could give some serious light.
the LED i found the original XM-L2 U2 i planned on using for the ZY-T08 mod. (i decided to used the led and maybe go for a emitter swap later withe a MTG2 or even a new XHP50 once i am able to buy it)
i started with converting the switch assembly from parrallel to series.
i cut the trace between the 2 spings. and olso cut the 2 traces from the witch to the screw holes.
then i made a cut for the wire from the switch to the spring. i broke the spring while making the cut so i had to improvice to get a new spring a the same hight as the other spring. i think i did a pretty good job keeping the path as low resistance as possible.
the i tested the driver. i hooked 2 18650 in series up to the driver and hooked the driver up to the led with my amp meter in between. i quick flash later and 0A showing on the meter i know i blowed a led. i was sure the stock driver of a TR-J19 was 4.5A parrallel. i guess i was wrong.
RIP: the first time i blew a led this way. worst past is that is was my last LED i had!
to do / need to buy:
-buck driver
-LED: XM-L2 or MTG2 (or XHP50 (please be available soon :nerd_face: )
-ZY-T08 reflector (AL or plastic)
if anyone has one of the above laying around i am willing to buy them at the right price (btw i live in europe)
————————[more to come when part arrive]———————————————————
