i really screwed up. after an emitter swap i was testing the voltage and slipped with one of the dmm leads and shorted the LED+ to housing and the light quit working, no voltage at the emitter. i put the emitter in another light it works no problem. Is the driver toast? repairable? does anyone have an original driver from their zy-t13 they would be willing to part with?
Sounds like its fried. Change out the driver if you’re able to.
the driver has a side switch for mode changing and is 23.48mm in diameter. not exactly commonly available.
You can just put a normal driver in, but of course your side switch won’t work anymore then.
If that’s a big deal, I can’t help you any further.
I would contact DrJones, he is the driver master.
Sounds bad. How does the driver look, anything looks burnt? It did sound like you fried it, and yes that driver is hard to find. Probably you’d want to swap a standard 8.4V buck driver for a while until you can find a replacement.
nothing looks burnt. however some components are buried in the “potting” compound. whatever failed it did so in non dramatic fashion. no sparks, no smoke, no smell. for the ideal situation would be find somone who removed the original driver and wants to sell it. i would like to keep the side switch function if possible. i would also consider giving someone here on BLF a shot at troubleshooting and repairing it. anyone want a crack at it?
