It looks like a drop or two of epoxy between the body and the switch would also solve the problem.
Mike
Mike
the force of pushing the button would then be held by the epoxy - IF it stuck and did not also get tweaked loose by button pressing…
wle
I have a few questions about the DQG 18650 Tiny 4th that I couldn’t find answered anywhere.
1) Is the driver in the light really constant current regulated? That doesn’t seem possible since the driver board seems to lack an inductor (though I can’t find a picture of the bottom of the PCB). At best it seems like it can maintain constant current only as long as the battery voltage stays above Vf using linear regulation or high speed PWM control (though I didn’t see a MCU either). The CNQG page, just says “Current Regulation”. I didn’t see any runtime vs. output graphs anywhere that would shed more light on this.
2) Can it fit protected 18650’s that are ~70mm long?
No, it’s linear
Chip Qx7137 http://www.go-gddq.com/upload/2015-09/temp_15090911368037.pdf
http://forum.fonarevka.ru/picture.php?albumid=1062&pictureid=15208
WARNING
the switch design is very bad
mine just broke off
at the SAME TIME it also failed, so i could not even solder it back
i had had it about 8 months, daily use but nothing extreme
i emailed the company dude, ric, he did not seem to care
wle
WARNING
mine broke off inside the light, after about 8 months of reasonable use
AND at the same time, it quit working, so i could not even solder it back
emailed company head, ric, he did not seem to care
(near the letter “K”, is where it SHOULD be)
wle
Same thing happened to mine with only a few weeks of moderate use, bad design the switch could of done with maybe some glue from a heat glue gun or similar behind to hold it rather than reliance on just the 2 solder pins to hold it in place.
shame as I liked it alot
i think it uses 4 solder pads, but still this the WORST design.
all of the force of pressing the button goes to bending it back… it is bound to fail
sorry to say
but i did like it
i bought another one when gearbest had them for $14, has not arrived yet
manker u11 is a better light, just bigger and heavier…
wle
Cross-reference on the switch failure, as there’s a separate thread for that also:
Yeah. My button is too broken today.
it’s like KLS7-TS3606 (3*6*5mm, horizontal) , SWT-11, TS-1135HS-180-003
When I tried to make a FET-modification of the driver.
Button badly soldered. Or it is because of lead-free solder.
I will add one FET transistor in parallel to the one that is responsible for the turbo mode (AOFV). Gate will be on 6th leg of microcontroller.
I could still change the transistors on the board for the best, with less resistance
http://s019.radikal.ru/i611/1612/cc/b73b1b0f7673.jpg
Does this flashlight have any kind of low voltage notification such as blinking or auto shut off? Trying to understand if non-protected cells are OK or if it’s safer to use protected ones in it.
The stock light has no protection for low voltage.
If it dims, switch battery or check it from time to time.
Or mod it
Is a faulty switch a common issue with this flashlight? I just received mine today. It worked fine the first couple of times, but now it only works sometimes. It either will not turn on or will not turn off or will not switch to a different mode most of the time. Is there an easy fix?
Edit: just found the warning thread related to this issues. I should have done more research before buying this junk.
Ok, so if I push up (toward the lens) on the switch button, it works. But if I just press straight down on it, it does not work. Is this normal?
yes it is unfortuately something that can happen.
as i had warned.
the guy from DQG used to post on here, i am not sure what happened to him.
does anyone know?
i emailed him when mine failed, (2 of them) but no response.
it would be great if the light worked
to answer other questions, it is safe with unprotected cells
what it does is step down levels until it gets to the lowest one, that one will blink to say things are getting low, then eventually it cuts off, protecting the battery
not sure what level it cuts off at but it seems OK for that function.
wle
DQG tiny 18650 IV?
yes it does have protection, it goes to lower modes and eventually shuts off.
wle
I just noticed in the OP photos that the head unscrews, but mine will not budge. Is there a trick to unscrew it or do I just need to eat some more spinach and try again?
it does unscrew—may be locktited in or something
doubt it
just use more juice
it;s kind of hard to grab, thin on the edge
use a rubber jar opener pad thingy
wle
I wasn’t aware or I forgot… So, what’s the cut-off voltage?
is possible to use for this flashlight unprotected cells?thanks
