The 1.5A would be nice but I don’t know if I can fit a 22mm driver in my M25C2 Turbo. It’s got a 92mm head, I’ve got a fet and a dedomed XM-L2 in there right now. The XHP35 HI foot print is a little smaller than the XM-L2 so it should throw further.
Thanks, appreciate the feedback. If they’re getting that close to a mile out of that reflector with “only” 2000 lumens then I see no real need to worry about bumping output. Dependability is a crucial factor in a search/spot light, sure don’t want it to fail during use for that last little tweak.
XM-L2 may have bigger die but the emitting area is much smaller than XHP35. My understanding is they throw nearly the same due to the similar lumens/area, but the XHP35 has higher lumens as it consume higher energy (wattage).
Left to right: XP-L HI, XM-L2 (dedomed halfway), XHP35 HI. (Sorry for dirty emitters, no cleaning done yet:))
[quote=Theodore41]
There is a Thread about K70 issues. Youtube - I posted a clip of both my K70 with “smoking”. Actually some one corrected me that it is not smoke (too serious), but kind like “fume” cause by evaporation of tiny particles or residuals on the emitter surface or the reflow base. It is due to very high heat of the emitter (changed to cooler tint at level 5 and 6) by overdriving the XHP35.
XHP35 rated only 1A in their spec, we all pushing it ~3 times higher. For such a small die LED, the wattage (40 W) is “world record” already.
(XM-L2 rated 3A, some push it to 7.2A which is 2.4 times only.)
Geez, thanks for bursting my bubble It’s better that way, no need to disassemble it again, lol. I’ve got a couple of old S4 2Bs laying around, they’ll shoot down range a little further but I’d rather have the bigger beam of the XM-L2.
This is a gorgeous and quite large light! The knurling is heavy, very easy to hold. It’s lighter than I would have expected. Battery carrier inserts in either direction. Samsung 30Q flat tops might be a bit short, they rattle. My side button is not showing a blue indicator light like the paperwork suggests, not sure what’s up with that.
I’m a numbers freak, admittedly, and this is serial number 2. Very cool!
The reflector. OMG! MASSIVE! My TM36Lite looks small beside it.
UI, somewhat different. Click to turn it on for access to L-M-H modes with last mode memory. Long press to turn it on in firefly. Double Click to hit Turbo from anywhere. A second double click for strobe.
I’m not sure I’m buying into the 600Kcd thing, the spot on the wall isn’t convincing me, but my meter will tell me something here in a little while.
Did I mention that the reflector is astonishing? The reflector is astonishing. The AR coated glass lens lets you really see the astonishing reflector. Flippin awesome! lol.
