Lets Talk Tints
[Pictures posted by jon_slider] Pictures are from a Nitecore Tip and Nitecore TipCRI
Nitecore Tip / Low CRI 6000K
Nitecore TipCRI / High CRI 3500K
I am trying to understand this, so I have a question or two.
jon_slider posted two pictures, each lit by a different tint. I can see that by looking at the pictures & (in addition he told us).
Aggressor, are you saying the colors we see in the pictures now may not have been the same as the colors our eyes would have actually seen the moment the pictures were taken??
And this could be adjusted, in a way the pictures would accurately represent what our eyes actually see at the moment the picture is taken; by setting ‘White Balance’ & adjusting colors with the Color Reference Chart???
Am I anywhere close to semi-understanding this or am I still wandering around in “left field” lost??? :wink:
Thanks in advance………. :+1:
teacher
Everything including time is relative; there is no absolute.
Even if all cameras were calibrated and too the monitor you are viewing the pictures, there is no way to be certain that your viewing, done by your eyes and nervous system, would be an exact copy of anyone else.
For most purposes ‘close enough’ is usually sufficient for making a decision on tints. :slight_smile:
Yes, that’s exactly right.
Except that simply adjusting white balance would have been good enough for light sources like Sun and incandescent bulb, while for light sources like LED using Color Reference Chart is required to get correct colors.
OK, thank you Aggressor; I am beginning to understand what you are saying then. :+1:
I appreciate your reasoning & explanations.
I have moved in from “wandering around lost in deep left field” to just semi-confused in shallow left. :slight_smile:
And to complicate things even more, a camera’s sensor and your computer’s monitor can not reproduce the full color space that your eyes can see. For example, a red-green-blue sensor or screen (which is almost every one), can not capture a true yellow, such as a dandelion flower. The best it can do is reproduce a slightly green version of yellow. Your eyes will see a more vibrant/true yellow flower in real life.
:slight_smile:
Perhaps one of those days I will write a post properly explaining the whole situation with light and color, there is enormous amount of confusion in this area. It is not an easy subject to explain…
+1
4C is my favorite and ofc the nichia 90 cri, dedomed 1A looks very good too
That would be good. :+1:
This is a good thread with a lot of good info so far. A big “thank you” to jon_slider, Aggressor, WalkIntoTheLight, techieman33, stephenk, and anyone else that has had provided knowledgeable input… it is appreciated. :slight_smile:
I have two Convoy L6 lights a N2-3A and a N2-3C; both are 5000K lights. I checked them both last night outside and inside and with my eyes could not discern a noticeable difference.
That makes sense to me. 3A & 3C are on either side of the 5000K line and above & below the BBL (broken line)
They pretty much look the same on the chart also…. “pretty much” being the operative words. :wink:
+1
The chart provided has been a great help in my understanding of tints and color temperature. :slight_smile:
It has to me also ‘sidecross’, once I learned how to read & understand it. :person_facepalming: … :wink:
I almost hate to admit this, but it is true. Quite a while back, just about the time I ran across this chart and was trying to make sense of it; I bought three Convoy S2+’s each with a CREE XM-L2 emitter in a different tint.
I got one of each of the one’s below, a different color S2+ for each tint:
  • Blue Convoy U2 1A - Cool White
  • Green Convoy T6 3B - Neutral White
  • Red Convoy T4 7A - Warm White
Then along with this chart and the “visual aid” being able to actually see first hand the difference in the tints… I finally began to understand.
Kinda sad I had to go to such lengths to actually understand…. but at least it worked for me. :wink:
+1
There are many ways to learn; your way had the benefit to include having new flashlights. :slight_smile:
Yep, the “visual aids” just kinda made it real. And, like you said; “new flashlights” were required to make that happen. :wink:
Probably part of my ‘sub conscious’ master plan……… :person_facepalming: … :wink:
I like variety :smiley: , close up work or uses then nichia 218b and 219c work well for me, the former at home and work, the latter again the same. For my work uses i like mules these days, took over from triples and quads for that soft wall of light.
triple 219c
Find 15% output works spot on, bonus with a mule is no bounce back off machinery and not fussy where to position it as it still floods the area even when set down bellow the subject.
Tend to not go bellow 4000k, prefer 4500-5000k ideally and even on my bigger hitters
6x xm-l2 5000k de-domed
I still enjoy the cooler side, sometimes i dont want or care for colours popping out, exaggerated reds and greens etc……………i just want to see colours fairly accurate. Bigger flood beasts or long throwing lights tend to come into this category
This is pretty accurate for 12x xpl’s at 5700k !
The light is my avatar and the x40 in this pic,
Love the infinite control ring UI and the huge copper heat sink that helps the 5000+ OTF wall of light run…………and run…………and run without heat issues for a long time.
I am good with the cool side as long as i dont get angry blues……….
Cheers ven
Good to see you here ven! :slight_smile:
Hey there bro :+1:
Guess it would be rude not to, been guesting it for ages, so much knowledge and seems a real great place of like minded cool dudes tbh. Love the politeness and the way you guys are………………unfortunately i am lacking in my own mods…… But trust me i admire the mods done here, really top notch stuff and take my hat off to you all.
O am a big fan of the s2+ lights(well convoy in general and simon is a great guy). Love the s2+ triples that are part of my rotation, either in 18650 or 18350 form
Dig a pic time……………well you know i like pics mr cross, far right, the red and blue are special (very special made) gifts for me and my son. The red is close to 9a and around 2800lm, the blue dialed back to a little 2000lm for Callum Both around 5000k of huge hot spot usefulness
Yes my lights get used, no real shelf queens, here is a quad xp-g2 5000k in work
:smiley:
3 of my little fav EDC lights part of my rotation, nichia 219B 4000k/219B 4500k and 219C 5000k
Here is the light color tutorial I came up with:
https://budgetlightforum.com/t/-/41748
