I looked at the link you put,but it is a mess there.The prices differ 50% between them.Which are good and which not.
I decided to use non-protected batteries that can be used in series; there are quite a few to choose from that have a positive terminal suitable for vertical series connection.
I use the Liitokala batteries in my single cell 26650 flashlights.
Or you can get them where I get mine………… RIGHT HERE . Never a problem so far with 3 separate orders.
That Jaxman connector works great by the way……. :+1:
I look at the alphanumeric writings on these batteries,and I see that there are not the same in different sites.Do you know if some of them are better than others?
https://www.aliexpress.com/item-img/Free-Shipping-2PCS-LOT-Real-Capacity-3-7V-26650-5000mAh-15A-Continuous-Low-Internal-Resistance-Li/32584248563.html#
https://www.aliexpress.com/item/1PCS-LiitoKala-26650-50A-5000mah-26650-Li-ion-3-7v-Rechargeable-Battery-for-Flashlight-20A/32547294353.html?ws_ab_test=searchweb201556_7,searchweb201602_3_10057_10056_10065_10037_10068_10055_10054_10069_301_10059_10058_10032_418_10073_10017_10070_10060_10061_10052_10062_10053_10050_10051,searchweb201603_2&btsid=3349139b-67ab-4a17-a7ae-f0cdcd7cb13b
I had no problem ordering the batteries either, what I tried to write is that the Jaxman ‘connector’ is no longer available from AliExprees.
My bad, I read it wrong. :person_facepalming:
Hopefully they will come up again, they do work real good.
Probably all the same.
I got all of mine at GearBest for right around $20 US for four of them and they all check out above advertised specs. :+1:
The LiitoKala 26650-50As can also be gotten at Banggood for a similar steal than at GearBest if you are wise to check out M4D M4X's deals.
Cheers ^:)
P.S.: in fact it becomes a slightly better deal, especially with 3+ units volume discounts.
[/quote]
[/quote]
Thank you teacher.
Hmm when I follow the link in my previous post I can add a jaxman connector to my cart so it seems available to me.
maybe jaxman just likes me
How are these Liitokala batteries with the Convoy L6?
Is it better to go with these or the short Keeppower 26650 5200mah?
They dont work with L6 - they are too short for L6( even with an added magnet) plus the tail L6 spring is kinda short one ….with S70 are fine though
Yet, its easy fixable
5200s are definately better, the flashlight is more productive with 5200 or 5500 Soshine
A little bit of solder on the top of the Liitokala should fix that shouldn’t it?
Indeed
Its a good idea to swap the L6 tail spring too, its kinda short and flagile looking, i already mailed Simon about that issue
My Liitokala with a solder blob on one of them have a good fit.
Keeppower 5200 protected (the new short ones) are also good.
The tailspring of my L6 has a lenght of almost 14 mm and is quite solid.
They work just fine in my L6.
Matter of fact, I have experienced zero problems using the LiitoKala 26650’s in any of my L6’s.
In fact I have one pair that works in series without any “fix”.
I use THIS with the others. Although a solder blob, magnet, or some other “fix” will also work just fine also. For my purpose though, the Jaxman Series Connector is about as simple as it gets and works just fine.
The LiitoKala cells fit fine in my L6. I used a small magnet to make better contact between the cells. Though I wouldn’t recommend the magnet without adhering it to the positive end of one of the cells.
Mine are 14mm also, substantial, as well as solid.
Personally, there would be no reason to replace any of the tail springs in my L6’s.
So would you guys recommend saving some money and just going with these Liitokala over the protected Keeppowers?
What spring do you recommend?
