The best heat conductive substrate for flashlight
I’m still thinking about ordering a 12mm wide man made diamond to put a hot emitter on top of…
Kindly give me your advice. :slight_smile:
You are right, it seems that you have contact with it. SinkPAD have this technology in USA, and we had done a couple of years ago. Recently used in a flashlight is very common.
:+1:
As the saying goes, musket to kill a butterfly.
Of course, money can’t buy you happy, imainly depends on your mood…
Mini heat-pipes… thermal conductivity can be orders of magnitude better then diamond and should allow the LED to be soldered directly onto it if profiled correctly and pressed into a MCPCB.
Another thing to add to the list of things to try.
The following is the structure of thermoelectric separation MCPCB.
Practical photos (XHP70)
Practical photos (DEDOLIGHT)
I can’t see the pictures you are trying to post. :slight_smile:
Really? Then how can I do it?
But I can see the picture I sent.
Try using the “picture” icon (7th from left) at the top of the Comment box. That is all I know to tell you.???
I do not know why, with your method the results are blank after insert picture. If “Text format” is “Advanced Post Editor”, using the “insert/image” ,it’s ok and I can see it.
I cant see the pictures either.
OK ? I just know I can’t see them. Maybe someone who knows why will chime in. :slight_smile:
Do you know the reason for it?
How philosophical. :face_with_monocle:
Where they are located (the images themselves)?
Maybe you should try uploading them at some public image hosting, like Imgur.
[quote=aliang802] Really? Then how can I do it? But I can see the picture I sent. [/quote] Where they are located (the images themselves)? Maybe you should try uploading them at some public image hosting, like Imgur. [/quote]
Image is located in my 360 cloud disk. Curiously, I can see my picture on the forum, but you can't.
If that’s the case, it might be a permissions issue. Try logging yourself out of your 360 cloud disk and load this page again and see if you can see the pictures. I know I can’t see them.
Can’t see them either. When you do load them using the picture icon set image size to 100% rather than pixels x pixels. This automatically sets the size to match the page.
With all the not so subtle hints I keep getting from my girlfriend about something called an engagement ring (huh?), if I did that, I’d have to sleep with one eye open.
