Nitecore site says the Tip can last up to 46 hours on Low of 1 lumen
Above photo shows 1 lumen draws 4.24mA
Lockout consumes 6.49mA, or 50% More than the Low mode, or as if the LED was producing 1.5 lumens of power drain.
Theoretically, Lockout should take 30 hours to drain the battery, but Ive seen reports of it lasting twice as long before going dead… :confounded:
this is actually Very Good Info!
I was wondering exactly that, whether the exposed buttons on the Tip were stiff enough to prevent premature activation…
Since There IS No Lockout…
That’s some good, (bad :person_facepalming: ); info will34! Your descriptive word pretty well sums it up too. :+1:
Reckon what they were thinking when they did that … Never mind, they weren’t thinking obviously……
I have a DMM just like yours too.
I read at other places where some TIP users said it turned on erroneously numerous times for them. But I don’t know if they were fumbling with it or what. Mine is on my keychain EDC…so far (6 days) it’s been 100%.
I measured 6.49mA for a solid 20 seconds, does it drop after a while? probably, it was tricky to mantain the DMM lead steady in that position. Maybe I’ll take it apart once more and solder wires for a longer measurement.
If I had to guess, it could have been them trying to rush the TIP to market, so proper and thorough testing wasn’t done. I remember there was confusion early on about the TIP CRI, whether it came in just one color temperature or two. It also could have been someone making a last second design change to the circuitry or whatever thinking it wouldn’t introduce any problems, so no thorough testing was done again.
But yeah, someone wasn’t thinking at Nitecore - they took a shortcut somewhere and ended up with a messed up lockout mode.
OK thank you, just wanted to make sure I understood. :+1:
Three blinks is somewhere above 50% isn’t it? Let us know when it drops down to 2 blinks…. I’ll be curious.
This is why I have no significant brand loyalties- anybody can make a turd and all that takes is not paying enough attention at the correct moment. If they’re so messed up as to design a lockout this badly when others do well, then they don’t deserve anyone’s respect or money. TBH every side-switch light I’ve pocket carried has self-activated, so without a low-drain lockout it’s nothing I could be convinced to use even if they gave it to me free.
If you admit an error and try to learn from it, people can be amazingly forgiving but if you try to CYA with excuses, people will remember that most strongly the next time you’re mentioned.
