Something stock that performs as well as my modded BOSS1 with a dedomed XPL V6. Interesting... With 2S2P cells, it would need a buck to work with a dedomed XPL, which we don't seem to have for an e-switch light. I would expect better throw in the TN42 with a dedomed XPL running over 6A.
I saw you bragging on the “noticeably brighter spill” elsewhere and this puzzles me. In actual use at the distances the light is capable of, a light that is made for long distance throw is best not having spill. With this “noticeably brighter spill” the eye is filled with close up illumination and long distances cannot be made out, completely destroying the intent of a long distance thrower.
It’s really difficult to look at a picture taken by someone else and comparing the light to another picture taken by yet someone else. The only real way to know how the K70 compares to the TN42 is a side by side comparison. Everything else is simply conjecture. It would be like me saying you must be bald because you chose a user name starting with the letter s.
As far as the serial numbers and text changes go in relation to cloning… I bought the light directly from Thrunite.
George, I bought mine directly from Thrunite when they announced it. Literally the same day they announced it. I did a pre-order and used their 20% discount code.
422Kcd compares how to 602Kcd? 1400 meters throw to over 1600?
I guess if someone is comparing the numbers on a website, just reading, it looks pretty close. Build a light that makes those numbers, tweak a light from 400 to 600, it isn’t as easy as it might seem.
I personally do not like the magnetic ring switch. I have a K50 and the magnetic ring function has given me issue. I primarily can only use it now in Turbo. SupBeam, AceBeam, whatever they’re called now, it’s a decent light but also pricey and that magnetic ring thing just blows it for me personally.
Other than that I suppose it’s just a personal preference as to style and weight, design, and yesterdays best thrower vs todays.
This is kind of funny. A thrower that throws better and accused being a fake and having a less bright spill... Wut? Someone has a thing against ThruNite? 7 months? How many new generation LED's has CREE produced in the last 7 months?
Hmmmm, interesting assessment. :+1: Not very accurate at all mind you, nor based on much of anything other than your opinion and that you “expected more from the TN42”; which all has nothing to do with fact.
What were you “expecting”? Did you want a thrower or something with a bunch of spill?
Your post leaves me wondering what your motives were in making it…… :question:
You post no numbers or any of your testing results. Just an opinion base on ???
EDIT: Oh yeah… what makes the UI better in the K70??? Please, educate me with some facts.
Great throwing light, until the next bigger reflector light comes out, no? Not like anybody on any of the forums actually designed and produced it! Nice job Thrunite! And it seems there is the potential for tweaking this one too!
50% bump in kcd and better than a blu-ish tint, foggy, whiney K70 in 7 months is pretty good. The High Intensity versions of the CREE LED's were announced in April of 2015, and still make the best stock throwers - nothing new for 1 1/2 years - now that's honest facts.
Back at it again Seery? Aren’t you the same guy that bashed the TM16GT, and said that it threw worse than the original TK75? While everyone else said otherwise.
Both lights are very bright, but the TN42 is a bit brighter. If you can’t handle not having the brightest light, just buy the TN42 and spare us your attempts to justify your purchase.
