Yeah Dale, dunno. I’ve been compiling a modified version of Biscotti today but haven’t had a chance to flash it to anything yet. The Biscotti source on launchpad has the following array of PWM values:
Every other line of PWM values (commented out) starts out at 3, indicating she usually does use 3 for moon. I think I typically stick to 4 to be safe. Not sure why this one starts at 1.
Dale, what repository are you looking at? I only see one active line of PWM values (line 82 here), and it starts out at 1. Does TK have another place she keeps code?
Hmmmmm, that is interesting.
Kinda like “damned if you do & damned if you don’t”. That is a tough place to be put in……… :weary: …
Personally I have a solution to that problem….
But, since it would not even be close to clearing the “PC Bar”; I will refrain from sharing it……… :smiling_imp: …
Possibly, but hopefully this is just a one-off situation. And while I like having the option of a moonlight mode… how often do you pick up a light the size of a C8 and say “I want an almost indiscernible amount of light from you!”?
This world takes all kinds of people! Some of us code all day long, some drive tractors, other save lives. We’ve all got an amazing role to play! (not to down play TK’s great work - code can be a work of art sometimes!)
TK sent me the code she was sending to Simon, I flashed it to a C8 for JDub as well as a different code set to a few other lights (mistakenly, sorry Jared!)
She very thoughtfully has the code set up for those who would like to tweak it to their own drivers, both FET and 7135 lines are present throughout, all one must do is choose which style they are using.
Please contact Simon through the store. I’ll mention it to him as well but I know he will want you to contact him directly. This is the first issue I’ve heard of but this is all completely new. Hopefully it’s just a fluke. Any problems will be resolved properly I’m sure. Simon would not ask you to “live with it”.
Good news, seems like it might in fact be a fluke. Just did a quick test of my 2nd new C8 that I had left at the office, and it doesn’t show that behavior at all. Moonlight seems to work just fine on my 2nd one.
In all the hundreds of drivers I’ve built using the ATTiny13A MCU, I finally got one that glitched. It “shifted gears” unreliably, randomly, with no rhyme or reason. Built a new one, next MCU out of the sleeve, works fine. So apparently there are random fluctuations in the components that allow for slight differences and this sometimes trips us up when we’re using parameters that are right at the edge to begin with.
I also once got a driver from a known high quality dealer that had a sense resistor glitch. Even the little simple sense resistors can seemingly be off by a significant margin once in a while. It’s been said before, if something CAN go wrong, it’s gonna find ME!
Thanks for the update, gentlemen. Glad it seems to be an isolated event.
And my apologies for calling TK’s code into question earlier. I was wrongly assuming that what was published on launchpad would be the same as what she sent over to Simon. :person_facepalming:
FWIW and until TK comments, PWM of 1/255 should work fine with this firmware.
(IIRC the PWM frequency is adapted to the mode: Lower frequency for lower modes. So the 7135s actually have time to consistently turn on fully even with very low PWM values.)
You may be onto something here. As I said, I haven't actually flashed Biscotti onto anything yet, so I haven't a clue. But Biscotti does adjust the prescaler and between Fast & Phase for the lower modes, so it very well could work with a PWM value of 1/255.
Edit: removed some misinformation to hopefully avoid confusion.
