it will be listed in a few days, wish you could like it too
Sorry if I missed it, but which LED are they using?
Ah, it says XP-L in the manual. Cool.
Nice specs. It does look like they tried really hard to get it right. I’d love to love this light for its features. But, it’s so ugly. I really, really, REALLY don’t like the ‘spline’ look. :cry:
Too bad that they were unable to make a driver with low quiescent drain. It shouldn’t be this hard to do.
And time for a traditional question: can it fit triple?
Haha, but for me the spline look is a refreshing break from all the usual stuff we see…beauty is indeed in the eyes of the beholder.
Maybe because it’s also looong. This seemed off to me so I checked the specs and it’s actually almost 2 cm longer than S2+, which is already pretty long.
It’ long because of the triple board driver design. The driver cavity is deep by necessity. It’s done well though, with the internal slots for the vertical driver board to fit into, any hard press on the switch just doesn’t cause issue like so many others.
Another look at the switch side of the board… I wasn’t targeting specific’s so these are the only pics I have at this point. I can get back inside easily now though.
It seems a bit large but you can’t say it’s not rugged looking. I would not mind trying one of those during my upcoming winter night shifts. That would soon reveal any flaws it might have!
Xoden, low quiescent drain is irrelevant with an on/off tail switch, yes? The light cannot be turned off from the side e-switch, so with the physical clicky switch at the tail quiescent drain does not apply here.
Some of the length is absolute, due to the USB charging port and the excellent cover design… threads are few but it still takes some space to have these threads with a physical dual o-ring cover to ensure the port is protected.
I measure 118.8mm on a Convoy S2+ and 136.2mm on the f1.
S2+ is 23.8mm diameter at the bezel, f1 is 26.3mm.
S2+ is 17.4mm at the reflector opening in the bezel, f1 is 20mm.
Reflector cup is approx 11mm on the S2+, the f1 reflector cup is approximately 20mm in depth.
Easy to see that the f1 is a larger more capable light with better throw characteristics and the built in charging system. A win as far as I’m concerned. More light than the expensive Nitecore P12GT with comparable features and still smaller than this class mate.
Very interesting light…very curious about the price!
On paper, the Zanfare F1 flashlight looks pretty good. The several styles of knurling/grip do make for an odd appearance, but that's not a deal-breaker for me.
No small tube light can hold a 1240-lumen output for very long, so the 30-second step-down in "Flare" mode is fine. The next highest mode, a 590-lumen "Turbo" mode, is a level that can probably be maintained without overheating.
Overall, the mode spacing is good. It would be better if there were a mode between the 1-lumen "Moonlight" mode and the 50-lumen "Low." Something like 10 or 15 lumens would be nice. Adding another mode, however, might create user interface issues. There are already five different constant modes, four of which are on the "main sequence." Inserting a new mode would make the main sequence longer. My opinion is that flashlights that have that many modes need to have mode switching in both directions, brighter and dimmer.
The recharging port cover is ideal. I have a general mistrust of the tiny rubber flaps used by most rechargeable flashlights. Zanfare has chosen my favorite design, a screw-on sleeve, sealed with O-rings.
The driver is said to be a constant current design that has both a low-voltage warning and cutoff (at 2.6 volts). Nice!
The User Manual does not describe recharging in detail. I presume that 1x18650 is the only battery configuration that allows recharging. Trying to recharge 2xRCR123 is probably not going work, but the User Manual fails to point this out. In addition, it looks like there is a typo in the User Manual. It describes CR123A as having a nominal voltage of 3.7 volts and RCR123 as having a nominal voltage of 3.0 volts. I think those are reversed.
Can the F1 flashlight can take 2x18350?
Based on the specs, I would say Zanfare has done a good job with it initial entry. I hope to see more from it. Models with neutral tint, CCT near 5000K, and high CRI would be of particular interest to me.
By repeatedly resetting the Flare mode, I’ve managed to get it pretty hot! Once it’s warmed up it won’t run as long in Flare but it does still go like 18-20 seconds which allows it to build heat over a period of 4-5 resets.
I tried engaging Flare from a medium mode to see if it would return to that mode on step down but it goes back to the lowest level.
I agree that mode spacing seems off, pretty big jump from moonlight to low. From Medium to High (Turbo?) is not very much of a visible jump, so it would be nice if they could pull back the middle modes to allow for a 10-15 lumen low, maybe a 60-80 lumen medium, then the high of 580 or a bit more. That would allow for 3 nice low levels for general use, a semi-Turbo mode that would stay engaged and Flare for those scenario’s when you need all that’s available.
Strobe is pretty fast, seems quite bright and of course I have zero use for any SOS level.
Edit: I know the manual says switching out of strobe is easy, but it’s not. It takes that 3 second press to get it to go back to moonlight, which is difficult to detect after being in strobe.
Nice review Dale. Very thorough!! Thank you for the time you spent showing us this light.
TL
Thanks DB,
my quick google foo points me to a Microchip 16f1823 i/st.
http://ww1.microchip.com/downloads/en/DeviceDoc/40001413E.pdf
not your standard Atmel chip but mod-able for sure.
I wonder what controls the USB charger circuit .
Hi Guys,
Good news that GearBest’s entry light, the zanflare f1 light is online now, welcome to order
and what’s more, latter we will have a $5 cheaper coupon to benefit BLF members :partying_face: , wish you like it
the coupon is only available during the presales ( please use it before Oct 28th )
That gives about $35…pretty high. I was thinking that it should be more in Nitenumen NE01 price range.
This is not ugly, it’s unique :+1:
Price could be a bit lower, ~30$ would be more attractive.
