Gearbest’s Deals ——- Sep 6th, $16.99 for Convoy M1 ( 2 in stock now )
Hi Serp, you could find it more cheaper deal here
18 september update
Category coupon for full priced product ( except some special products ) flashlight http://www.gearbest.com/led-flashlights-c_11265/
price: 12% off discount - coupon: LIG12OFF
1.Nitenumen NE01 Updated VER LED Flashlight - UPDATED VERSION
● CREE XP-L V5 LED, maximum output up to 1060 Lumens
● 7 modes: turbo; high; mid; low; moonlight; strobe; SOS
● Lock-out function prevents accidental activation
● Built-in Micro USB charging port, intelligent Li-ion battery charging circuit
● User-friendly red and blue battery indicator, low-voltage warning
● IPX-8 waterproof standard ( 2m ), let alone rainy days
● Aviation aluminum vacuum electroplating reflector offers 236M far beam
● Intelligent constant current driver circuit ensures constant output
● Precise temperature control system adjusts output according automatically
● 320h ultra long runtime, compatible with 18650, 16340 and CR123A batteries ( not included )
2. WUBEN E346 300LM CREE XP-G2 LED Flashlight
● Perfect for home use, camping, hiking, searching, trekking, hunting, fishing, car emergency, etc.
● CREE XP-G2 LED gives out super bright and stable light beam with low energy consumption
● Two lighting modes ( low, high ) are suitable for different occasions
● Special appearance design, wear-resisting, impact resistant and scratch-resistant
● IPX8 waterproof function allows you to use it in any weather
● Made of aluminum alloy, durable to use and sturdy in hand
● Twist the head to turn on the light and adjust the brightness
● You can charge the battery rapidly by any devices with a USB port, such as computer, desktop, laptop, power bank
● The key ring for easy carrying
● Powered by 1 x 16340 800mAh battery ( included )
● Impact resistant to 1.5M
● Lightweight, compact and small size
● After fully charged, it can be used for 1.2H at high brightness and for 11.5H for low brightness
● Light source: CREE XP-G2
3. WUBEN I333 1200LM CREE XPL-V5 LED Flashlight
● CREE XPL-V5 LED gives out super bright and stable light beam with low energy consumption
● Seven lighting modes ( moon, low, middle, high, super bright, strobe, SOS ) are suitable for different occasions
● Lotus head can smash the glass easily, which can help you to escape as in emergency
● With the power indicator function, you can know the battery power clearly ( when button W is blue, the battery power is more than 30pct. When button W is red, the battery power is more among 30 - 10pct. When button W is red with flicker, the battery power is less than 10pct )
● The switch is on the tail of the light, convenient to use by one hand
● With the clasp, easy to hang in outdoor bag and jeans
● The rope for easy carrying
● Powered by 1 x 18650 2600mAh battery ( included )
4. Manker E11 Mini LED Flashlight - 1A 6500K
●Brand: Manker
●Model: E11
●Lamp Beads: Cree XP-L
●Beads Number: 1
●Lumens Range: 500-1000Lumens
●Luminous Flux: 800 (14500) / 400Lm (AA)
●Color Temperature: 6500K (1A) / 5000K (3D)
●Switch Type: Clicky
●Switch Location: Side Switch
●Feature: Cooling Slot of High Efficiency,Lanyard,Lightweight,Pocket Clip
●Function: Camping,EDC,Hiking,Household Use,Night Riding,Walking
●Battery Type: 14500,AA
●Battery Quantity: 1 x AA / 14500 battery (not included)
●Mode: 4Mode (High > Middle > Low > Lower)
●Mode Memory: Yes
●Waterproof Standard: IPX-8 Standard Waterproof
Interesting new lights, the updated nightnumen without the bug and the wuben brand, thanks for sharing.
20 september update,
Category coupon for full priced product ( except some special products ) flashlight http://www.gearbest.com/led-flashlights-c_11265/ can be bought for additional 12% off discount, with the use of the code - LIG12OFF
1. ThruNite TN42 LED Searchlight - 5000K BLACK
● Utilizes Cree XHP35 HI LED delivering up to 2000Lm output
● 6000K white light and 5000K neutral white light are available
● Multiple outputs: 5 constant brightness outputs and emergency Strobe mode
● Optimized SMO reflector for maximum 1550m throw distance
● Instantly access to Eco, Turbo and Strobe at any time
● Runs on 4pcs 18650 batteries ( not included ), which provides up to 58 days runtime
● IPX-8 ( 2m ) waterproof standard is ready for all-weather conditions
● Constructed from T6061 aero-grade aluminum alloy in military-grade hard anodized finish
● Toughened ultra-clear double glass lens with anti-reflective coating, 99pct light transmittance
Outdoors & Sports ( including knives ) http://www.gearbest.com/lifestyle-c_11270/show.html?odr=trending can be bought for additional 12% off discount, with the use of the code - OUT12OFF
2. Ganzo G7531 - BK Foldable Knife - BLACK
- 440C stainless steel blade and G10 handle
- With rivet on the blade, more convenient for you to open the knife
- Semi-automatic quick opening feature, faster to unfold / fold the blade than normal knives
- With hanging clip on anti-slip handle, convenient to carry
3. Ganzo G7533 - GR Foldable Knife - GREEN
- 440C stainless steel blade with titanium coated and G10 handle
26 september update
Category coupon for full priced product ( except some special products ) flashligh (link is external) can be bought for additional 12% off discount, with the use of the code –*LIG12OFF*
1. JETBeam JET - II MK EDC LED Flashlight - $29.45
_
Lamp Beads: Cree XP-L HI
Beads Number: 1
Luminous Flux: 510LM
Luminous Intensity: 4800cd
Color Temperature: 6500-7000K
Switch Type: Twisty
Feature: Lightweight,Pocket Clip,Tail Stand
Battery Type: 16340,CR123
Battery Quantity: 1 (not included)
Mode: 4 (High > Middle > Low > Lower)
Waterproof Standard: IPX-8 Standard Waterproof (Underwater 2m)
2. AIMAI C16G LED Searchlight - $24.46
_
Lamp Beads: Cree XML-T6
Beads Number: 12
Lumens Range: >2000 Lumens
Luminous Flux: 2900LM
Color Temperature: 7000-7500K
Switch Type: Clicky
Feature: Cooling Slot of High Efficiency,Stainless Steel Bezel
Function: Camping,EDC,Exploring,Household Use,Night Riding,Rescue,Search,Seeking Survival,Walking
Battery Type: 18650
Battery Quantity: 4 (not included)
Mode: 5(High-Middle-Low-Strobe-SOS)
Waterproof Standard: IPX-7 Standard Waterproof
28 september update
products of category of the” LED Lights & flashlight”:http://www.gearbest.com/led-flashlights-c_11265/ ( full-price item)could get 8% off discount via the coupon of GBLED2016
1. Zanflare F1 LED Flashlight XPL V6 - 39.99$
Lamp Beads: Cree XP-L V6
Beads Number: 1
Lumens Range: >1000Lumens
Luminous Flux: 1700LM
Color Temperature: 6000-6500K
Switch Type: Clicky
Switch Location: Tail Cap
Battery Type: 18650,CR123
Battery Quantity: 1 x 18650 or 2 x CR123 batteries (not included)
Mode: 7 (High; Middle; Low; Ultra-low; Strobe; SOS; Location Beacon)
Mode Memory: Yes
Rechargeable: Yes
products of category of the” LED Lights & flashlight”:http://www.gearbest.com/led-flashlights-c_11265/ (link is external) ( full-price item)could get 8% off discount via the coupon of GBLED2016
7 October update
1. MecArmy PT60 LED Searchlight - $299.90
Lamp Beads: Cree XP-G2
Beads Number: 16
Lumens Range: >9000 Lumens
Luminous Flux: 9600LM
Luminous Intensity: 43238cd
Feature: Anti-Roll Rugged Design,Cooling Slot of High Efficiency,Power Indicator,Stainless Steel Bezel,Tail Stand,Tripod Mount
Function: Camping,EDC,Exploring,Hiking,Household Use,Law Enforcement,Night Riding,Rescue,Search,Seeking Survival,Self-defense,Walking
Battery Type: 18650
Battery Quantity: 13600mAh battery pack (4 x 3400mAh 18650 protected battery)
Mode: 6(Turbo - High - Mid - Low - Strobe - SOS)
Rechargeable: Yes
_
2. UltraFire U - 58 Zooming LED Flashlight* - $4.08
Lamp Beads: Cree XP-E
Beads Number: 1
Lumens Range: 200-500Lumens
Luminous Flux: 389LM
Color Temperature: 7000k-7500K
Feature: Cooling Slot of High Efficiency,Lightweight,Lotus Head,Pocket Clip
Battery Type: 14500
Mode: 3 (Low - High - Strobe)
Zooming: Yes
_
3.DQG SPY 10180 LED Flashlight BRAS - $23.23
Beads Number: 1
Lumens Range: 1-200Lumens
Luminous Flux: 120LM
Color Temperature: 4250-5000K
Switch Type: Twisty
Feature: Lightweight,Reverse Polarity Protection,Tail Stand
Battery Type: 10180
Battery Quantity: 1 (included)
Mode: 2 (High > Low)
LED Lifespan: 50000h
_
4. ROFIS TR20 18650 LED Flashlight - $64.32
Lamp Beads: Cree XP-L HI V3
Beads Number: 1
Luminous Flux: 1100LM
Luminous Intensity: 10850cd
Feature: Angle Head,Lanyard,Pocket Clip,Reverse Polarity Protection,Tail Stand
Battery Type: 18650,CR123A
Battery Quantity: 1 18650 or 2 x CR123A (18650 included)
Mode: 6 (Turbo; High; Mid; Low; Lower; Strobe)
Rechargeable: Yes
MecArmy PT16 - Ti LED Flashlight - SILVER is gorgeous but US259.90 :disappointed: !!!
I don’t think it’s worth even half what they ask…
The brass version is also a beauty, but I'd pay no more than $60 and they want $190? Yep, a little insane. I can get 1200 out of a 18350 light for a whole lot less for sure.
Hhmm, $10 for a Convoy S2+ 18350 host, maybe $12-$15 for the LED and driver.
17 october update
flashlights 18% off discount from full price USE CODE - LIG18OFF
1. Convoy C8 LED Flashlight - V2
_
Luminous Flux: 993LM
Switch Type: Clicky
Feature: Integrated Heat Dissipation Design,Reverse Polarity Protection
Battery Type: 18650
Battery Quantity: 1 x 18650 battery (not included)
Mode: 2 Kind of Mode (1. 3 Modes: Low 5; Mid 40; High 100; 2. 5 Modes: Low 5; Mid 40; High 100; Strobe; SOS)
Mode Memory: Yes
2 Convoy L6 LED Flashlight - N2 3A
_
Lumens Range: >3000 Lumens
Luminous Flux: 3800LM
Switch Type: Clicky
Switch Location: Side Switch,Tail Cap
Feature: Anti-Roll Rugged Design,Cooling Slot of High Efficiency,Die-cast Unibody,Instant Strobe
Battery Type: 26650
Battery Quantity: 2 x 26650 Battery (not included)
Mode: 5 (Turbo; High; Middle; Low; Strobe)
3. Klarus XT11GT Tactical LED Flashlight - CREE XPH35 HD E4
Luminous Flux: 2000LM
Luminous Intensity: 24964cd
Switch Type: Clicky,Tactical Switch
Feature: Anti-Roll Rugged Design,Dual Tail Switch,Lightweight,Lock-out Function,Overheating Protection,Pocket Clip,Power Indicator,Reverse Polarity Protection,Stainless Steel Bezel,Tactical Ring
Battery Quantity: 1 x 18650 or 2 x CR123A batteries (18650 included)
Mode Memory: Yes
Rechargeable: Yes
2017 March 17th
ROFIS TR10 LED Flashlight - BLACK
features: 900Lm Cree XPL HI V3 Tiny Size Angle Head Magnetic Tail
will be sales flashlights at $3.33 :question:
wow, thanks for your comment, but the $3.3 just a activity price, can’t be happen offen, but please keep the eye on my deal thread, I may have more other deals
Congratulations for purchasing our zanflare flashlight. You have chosen a high quality product designed from the latest technology.
Zanflare F6 EDC Flashlight Cree XP-G2 200 Lumens IPX8 waterproof
URL: http://www.gearbest.com/led-flashlights/pp_622807.html?wid=21 (link is external)
Material: Brass
Cree XP-G2 with a lifespan of more than 50,000 hours
Body diameter: 14.6mm
Product weight : 31g
Reflector: orange reflector
Drop test impact resistance up to 1.5 meters
Color temperature: 4500K-6500K
Micro USB charging port and* indicator*
Full charging time is about 1 hour
The end is magnetic and can serve as a whistle
Coupon —ZF6DEAL
Coupon price —- 17.99$
Nice flashlight Gearbest!!
The first Zanflare flashlight that I have no design objections against. It takes the small 10180 flashlight type a bit further with a magnetic tail and a wistle (I never have use for a wistle but I like the idea, i.e. much better than the mandatory bottle opener that they put in everything while you can open a bottle with just about every random object in sight, including the Zanflare F6 ). And I like the looks and that it is made of brass.
Ok then, one design objection: really a next level would be to get rid of the annoying twisty and put in an electronic switch.
The Zanflare F6 looks very interesting.
The Zanflare F6 is very interesting but it does not include the battery, no store sends separate batteries to my country
Uruguay, right? It will be new breakthrough for us, right?
MiBOXER C4 Smart Battery Charger offers flexible charging current options, it is 4 slots LCD dispaly and compatible with Li-ion, Ni-MH, NiCd and LiFePO4 batteries.
2017 April 19th
MiBOXER C4 Smart Battery Charger—EU/US Plug
4 Slots LCD for Li-ion Ni-MH NiCd LiFePO4 Batteries.
MiBOXER C4 is an integrated digital LCD screen clearly displays charging parameters and progress, an intelligent automatic power-off function terminates current when charging is complete.
With flexible charging current options, broad battery compatibility and multiple protections, the C4 is the one and only charger you would need in various scenarios.
URL: http://www.gearbest.com/chargers/pp_624386.html (link is external)
Coupon: MiBOXER
Coupon Price: 26.99$
Compatible with Li-ion, Ni-MH, NiCd and LiFePO4 batteries
Capable of charging different types and sizes of batteries at different current simultaneously
Each of the slots monitors, displays and charges independently
LCD and LED display charging parameters and progress
Optional charging voltage: Ni-MH 1.48V, LiFePO4 3.6V, Li-ion 4.2V / 4.35V
Reversed polarity / over-charge / over-voltage / over-current protection
Made of durable fire-retardant ABS material, durable and safe
Parameter:
Input voltage: AC 90 – 260V 50 / 60Hz, DC 12V ( charger )
Output: 4 × 1.48V / 3.6V / 4.2V / 4.35V + / – 0.05
Input current: 2A
Output current: 0.1A / 0.25A / 0.5A / 1A
