Wait… Dr Jones driver definitely uses pwm on all four colors. I can infinitely adjust each color separately including white and yet blend them all to be on at the same time. So there must be a way, no?
Or, maybe you could talk DR Jones into tweaking his firmware for this new board. He may do that for a decent price. But, an open source solution would allow us to carry it forward and make changes and tweaks to our liking and to fit future boards, etc.
I’ve been trying to get ahold of him but he hasn’t been around the forum for a while and I don’t have any other contact info for him. I would be willing to pay for a completed rgbw firmware that I could use on self built drivers. Idk if he would’ve good with that though?
His driver firmwares are proprietary code. But, he used to sell pre-flashed MCUs. I would think he’d be willing to make a tweaked version for a new board if there was enough demand. How different is your board from his self-designed RGBW driver? If it’s basically the same, or not much different, his code may already work for you. It would be nice if you could get in touch with him. But, like I said above, it would be even better if someone came up with an open source RGBW firmware that was as nice as DR Jones or tterev3 code.
Ya. For me, his existing firmware is great! If I had the choice I would change the mode to clicks configuration, but if I could get an MCU from him as, I would be thrilled. I have one of his drivers left and I plan on removing the programmed MCU to place on my own driver layout. I’m working on a multilayered driver to power 4 XML rgbw led’s as well as one xpg3 high cri led. It will control three banks of 7135s and one fet channel for the white. I’m going to parallel the xpg3 along with the four white dies. When testing, I can get 4amps to the xpg3 and 1amp to each white die when in parallel.
At first, I was planning on using an escutcheon modified BLF d80, but room was very very tight. I found a way to pack it in with a custom driver design, but I finally surrendered to the pk26 as a host. After receiving the pk26, I’m still not certain it will work out. Even if it never works out, it’s been fun thinking about a 40w rgbw pocketable flashlight. (40w for about 40sec that is )
TK, if you want his driver board minus the MCU for testing, let me know.
(Edit: that is, dr jones driver board I am referring to.)
I found this instructable for software PWM. I’m not near versed enough to know what this entails, but the instructable gives a little hope for another good four individually addressable PWM controlled driver.
I got kind of ninja’d by other parts of life for a few months.
Also, um, I don’t actually have any driver boards to print and build. Texas_Ace, do you have these up on oshpark? I didn’t see the saber driver listed there.
I think it’ll probably work. If you’re willing though, it’d also be nice to have one with a pin and pad for an e-switch instead of the voltage divider. I think I can probably use the inverted VCC method for measuring voltage, and an e-switch likely makes the interface easier to navigate.
Or I could maybe use the 4th PWM pin for an e-switch, and use only three colors. I’m not sure how much value there is in adding a 4th color channel, and it should be fairly easy to stick the switch wire into one of the vias on pin 2 or 3.
Is there no use for adding a little bit of white to the mix? You can get some bright tinted colors this way. But I must say, I have no idea how a saber is yo be used:)
The idea was that you could use the R1/R2 pads to setup the e-switch if you didn’t need the voltage divider. I went ahead and added a dedicated set of pads for the switch though.
