This is a review of the ThruNite TH20 Headlamp. The light was sent to me by ThruNite in return for my review , as always I give my honest opinion of the lights I review. Amazon Link for light HERE
First I did not mention in the video that this light has a “lock out” by turning the end cap 1/16 to 1/8 of a turn to prevent any accidental switching on. Also I wanted to say that one handed operation is NOT a problem when wearing the headlamp.
This is my first headlamp with any kind of quality , as all the others I have are the 4 or 5 dollar department store variety. The TH20 is a very solidly built light with nice anodizing and machining both. The headband is comfortable and the light stays in place well. You simply turn the light a bit in the holder to adjust it up or down more. I really like the Ramping or “infinity” firmware , as you can go to any brightness level , with NO predefined modes. The light also has mode memory , so it comes back on at whatever level you choose when the light is turned off and back on later. The “firefly” mode to me is just the right brightness , but that is my personal preference and may be more than some like.
Overall I am really liking the TH20 and for just under $30 I think it is a good buy for a nice quality light…
The rest is covered in the video , again please note that my cheap video camera DOES NOT show nearly as true to life as the still photos in the slide portion of the video , as to what your eyes see.
The video , links for different countries and the ThruNite main site that they supplied , followed by the listed specs .
Amazon US: https://www.amazon.com/dp/B01FCTD9PG/
Amazon CA.: http://amazon.ca/shops/A1BNV2EQ2FFXQR
Amazon UK.: http://amazon.co.uk/shops/A2DUUB2J3TY3X1
Specification
Model TH20 Cool White LED Headlamp
LED: Cree XP-L V6 LED with a lifespan of 20+years of run time.
Mode & Runtime: (test by AA 2450mAh battery)
- Firefly(0.3 lumens, 14 days)
- Infinity Low(1.6 lumens, 21hours)
- Infinity High(230 lumens, 9.5 Mins)
- Turbo(250 lumens, 93 minutes)
- Turbo:(520 lurens, 37 Mins)(test by 14500 750mAh battery)
Battery Applicable: one AA battery or one 14500 battery.(No Included)
Working voltage: 0.9-4.2 V
Reflector: Orange Peel.
Peak Beam Intensity: 1120 cd
Beam Distance: 67 m
Dimension: 24.5 mm * 70 mm .
Weight: 96 g(without battery).
Waterproof: IPX-8(2 m, 30 minutes).
Impact Resistance: 1.5 m.
Material: Aircraft grade aluminum body structure with premium type III hard anodized anti-abrasive finish.
Accessories: O ring, Rubber holder.
Operation
Turn ON/OFF:
Single click the switch to turn the light on and off
Change modes
When the light is off, long press the switch to get firefly. Then long press the switch to circle through infinity high and infinity low.
Double click from any mode to get turbo,another double click to get SOS…
Memory function
The light will turn on in the last mode accessed,except for firefly,turbo and SOS.
