Agree, while I have a lot more 18650 lights, I only keep a AA lights in the car glove box. AA are available nearly everywhere from your local gas station to dollar stores.
Agreed. Though I have to say I absolutely love my Jetbeam Jet-I MK. Yes, it has a not-so-good (meaning “bad”) clip. And it’s a twisty (though a good twisty). And the tint is cool. I’d love it even more if it had a high CRI emitter and a better clip, but it’s still my favorite EDC at the moment.
I’ve been hoping that On the Road might jump into the fray and put out a great, affordable AA / 14500 model in the same way they hit the budget 16340 space with their M3. I doubt if they’d put a 219C in it, but we can pray.
Or Astrolux? Manker? Whoever it is, someone should put out a great, moderately priced AA / 14500 torch with a high CRI emitter soon. I’d buy three of them.
I agree. 18650 lights may have great chip in them, higher output and other cool things, but nothing can beat a good old single AA tail clicky for emergency situations.
I’m happy with my twisty Jet 1 and modded MiniM*g, etc., and tail-clicky WK50. Well, the switch on the WK50 kinda bites. I guess given those 3, 2 twisties win out over the 1 clicky.
For a small form-factor, a twisty is (to me) a bitlot easier to handle.
Could you use this for blackouts? Docooler Outdoor Solar Powered LED Spotlight Lamp 6 LEDs For Pool Use- Amazon.com
The charger part and the light part have a 10’ cable between them, so it would be good to prevent total darkness in some central part of the house, for bathroom visits and general moving around without need of a flashlight, just run the cable through a window with the charger portion outdoors, it also uses a single AA battery.
And advice I give to people about that: keep the AAs outside the light (eg, scotch-taped to the side) in case they leak, and have a spare (set) also kept separately. Nasty nasty nasty when alkies leak inside a light, and then grow fur and solidify.
To my feature list I would also add micro-USB charging port.
Olight S15R was charging only 14500 as far as I remember. Don’t recall anything that could charge eneloop inside the flashlight. And it’s not budget…and bad tint…and not a tail clicky.
Wish Neal was still here… Then we would know that at least they would read it and consider it.
But if this is picked up (by Astrolux, or even ‘Zanflare’), I hope they understand that succes of a new budget AA light is 99% related to an efficient boost driver with good user interface. Using a run-of-the-mill chinese AA driver with low efficiency, low frequency PWM and bad modes and spacing will make it another so so light at most useful as a host. Examples: Manker understood it well, they have developed some great drivers for their AA lights (but personally I do not like the designs and they are too expensive to be budget), and Thorfire did not get it (the TG06 is a very nice design IMO, but it has a very disappointing driver).
